Puzzling electrical problem - Nissan Versa Forums
post #1 of 5 Old 02-19-2013, 12:24 AM Thread Starter
Hello. First post. Thanks in advance for any/all input. Much appreciated.
Have 2007 versa hatchback. Left brake light went out. Also noticed high mounted third brake light is very dim and flickers when brake petal depressed. Right brake light works fine.
Replaced left brake bulb. Heres the kicker. Both brake lights now work but only when the headlights are off. Third light is still dim. When I turn the headlights on, the left brake light appears to be on, i.e. both running light and brake light appear activated. Right brake light still works perfectly normal. Third brake light still very dim and flickering.
Found a somewhat similar post where someone had this problem with headlights and brake lights but their issue was all three brake lights. And I have the dim/flickering third light.
Brake switch seems to me like it would affect all three lights....
I almost don't care about the third light, if I could just get the brake lights to work normally, but I have a hunch the two are related.
Any thoughts? Sounds to me like a difficult to locate short somewhere but just wanted to make sure someone else didn't have any good ideas.
romeslate is offline
post #2 of 5 Old 03-19-2013, 07:54 AM
Sounds like a corroded ground IMO. I had issues with the electronic hatch release not working and was able to find a ground wire that had a ton of corrosion on it. I'd just follow the ground wires, they can't go too far.
s10th is offline
post #3 of 5 Old 03-19-2013, 12:55 PM
Quoted: 33 Post(s)
I agree - sounds like a ground is causing the problem. Could be simply a loose bolt for the ground or some wires strand are broken and intermittently contacting each other.
Also, may as well check the fuses to ensure they are not loose and there are no hairline cracks or whatnot.
Versa12 is offline
post #4 of 5 Old 03-19-2013, 04:23 PM
VinnieVersa's Avatar
There was a link on this site where the Repair Manual for different Versa years was available. I can't find it now, but if someone would post the link, it would be helpful to identify the location of the ground points.
VinnieVersa is offline
post #5 of 5 Old 03-19-2013, 04:30 PM
Index of /FSM//Versa
I saw a Versa the other day with this same problem. Hope you get it fixed.
electrical
