Engine warning light on - Nissan Versa Forums
  • 1 Post By ram1220
  • 1 Post By Cobb
post #1 of 7 Old 09-08-2017, 02:42 AM Thread Starter
Quoted: 7 Post(s)
Dear All,
Hope everyone is doing fine.
I have nissan tiida 2008.
Yesterday night the engine warning light went on (check attachment). What could be the reason?
I have changed the battery recently and also changed engine oil 1000+ km before.
Any advice?
Thanks in advance.
mohrayafr is offline
post #2 of 7 Old 09-08-2017, 05:00 PM
Originally Posted by mohrayafr View Post
Dear All,
Any advice?
Thanks in advance.
The attachment you mention did not make the trip with your message. If you could tell us the code that came up, somebody may have an idea or two.
post #3 of 7 Old 09-09-2017, 02:36 AM
Quoted: 102 Post(s)
X2, the light coming on says likely there is at least one code logged in there.
Do NOT tell us what the code means, rather the EXACT number it is. DON'T accept what the person reading it says either, look over his shoulder to see the number yourself and write it down.
post #4 of 7 Old 09-09-2017, 06:06 PM Thread Starter
Quoted: 7 Post(s)
Thanks for the replies.
Sorry pimperell, I tried a lot but the file is not getting attached.
A friend of mine has OBD scanner. He did a scan and it didnt show any error codes.
He said it could be some memory overflow or something and did a reset.
The light is gone for now. He advised me to continue driving the car and keep a watch on the warning lights.
Please advice if we did the right thing?
Also, is it wise to buy a scanner and keep it for myself.
If so, which one would be appropriate.
Thanks all for your advises/suggestions.
post #5 of 7 Old 09-10-2017, 02:21 PM
I use a Scanguage II which runs about $150. It can read and clear codes, but it is also a "real time" information center that can display various information that you can customize to your liking. I have mine set for "water temperature", voltage, Rpms, and GPH used. It also has a trip calculator that you can use to see exactly what kind mileage you are getting and a host of other information that you can customize. It is portable, can be used on diesels and will work on almost any vehicle. Good luck with your car.
post #6 of 7 Old 09-16-2017, 08:12 PM
Quoted: 11 Post(s)
+1 I bought the Scanguage II when I bought my Versa S sedan last year and highly recommend it.
ram1220 is offline
post #7 of 7 Old 09-17-2017, 02:37 AM
Most auto stores in the US can scan codes and tell you about them. How about your country?
+1 on the scan gauge. It will allow you to clear codes and see pending codes. It also allows you to see details of sensors like coolant temp, AFR, battery voltage, intake air temperature, mpg, gallons of fuel use per minute and if you add the cost of fuel it will tell you how much the car is costing you fuel wise to drive.
