I'm looking to buy a Trailer Hitch for my Versa 2009 - Nissan Versa Forums
post #1 of 15 Old 12-05-2018, 04:46 PM Thread Starter
I found one on ebay for $166 https://www.ebay.com/itm/Curt-Class-...AAAOxySE9Q5LFQ
I wonder if anyone has a used one for less?
Thanks.
vaulter is offline
post #2 of 15 Old 12-05-2018, 08:14 PM
Quoted: 41 Post(s)
Most towns have a welding shop that specializes in hitches. I would check locally. My guess is that it is going to be close to that price but you may get installation included.
https://www.etrailer.com/p-C11378.ht...&hhmodel=Versa
Found this one on the web
post #3 of 15 Old 12-08-2018, 10:41 AM
Quoted: 84 Post(s)
In the old days the dealers were smart enough and cared enough about driver safety (and dealer liability) to never allow towing on the smaller engines as it tears them up pretty quick if overloaded and if towing anything at all on a 2 liter or less you are pretty much overloaded and even worse with the modern OD trans ratios now used. The owner manuals used to always say never tow with a four cylinder. Fast forward to today and drivers with no clue and the dealers will tell you you can tow with a tricycle as it wears the engines out faster and sells more new cars that way.
Yours and do as you will but I used to replace the engines that were towed on at way less than 100K miles for a delivery company, them being slick--ssed worn out at that low miles.
Not talking about a one time light tow but if you do it on a regular basis you are asking for it. A 2.5 will probably be OK but nothing smaller.
post #4 of 15 Old 12-09-2018, 05:03 PM Thread Starter
I am not going to tow any trailers with it. I only need it to tow my 400lb motorcycle for 15 miles to a shop.
vaulter is offline
post #5 of 15 Old 12-09-2018, 06:59 PM
Quoted: 46 Post(s)
If you expect it to be a one time thing, maybe you can borrow a pickup truck with a ramp.
post #6 of 15 Old 12-09-2018, 07:54 PM
Quoted: 41 Post(s)
Don't forget to take the chain off prior to the towing......
post #7 of 15 Old 12-10-2018, 02:07 AM Thread Starter
why is that?
I thought putting the gear on N should be enough.
vaulter is offline
post #8 of 15 Old 12-10-2018, 09:30 AM
Quoted: 41 Post(s)
You have a 'wet' clutch. So there is oil between the clutch plates. If you spin one side (either the clutch disks or pressure plate disks) by rotating the back wheel you will heat up the oil expand the clutch plates and at best burn (wear) them quite a bit, at worst they expand, make contact, and begin spinning the engine. Not sure about your bike but it probably has between 5 and 9 clutch plates. The distance between the plates is fractions of an inch so spinning one side will heat them very quickly.
post #9 of 15 Old 12-10-2018, 11:08 PM
Quoted: 46 Post(s)
Will keeping a clutch handle squeezed (for example using cable zip ties) make it safe?
post #10 of 15 Old 12-11-2018, 09:22 AM
Quoted: 7 Post(s)
A motorcycle clutch does not spin when the transmission is in neutral. I'm a motorcycle mechanic. The oil pump however does not pump oil to the transmission when the engine isn't running so eventually the gears and bearings get starved for oil. Removing the chain is necessary for long distance towing but I wouldn't bother for 5 miles.
Q Myers is offline
