Engine starts and stall in 1-2 sec - Page 2 - Nissan Versa Forums
post #11 of 36 Old 04-10-2019, 12:05 AM Thread Starter
Hmm
No error codes.
There was only P0304 ... misfire on 4th cylinder.
I did TB relearn but no change.
Still one sec run than stall...
Vrso2 is offline
post #12 of 36 Old 04-10-2019, 12:47 PM
Quoted: 92 Post(s)
Originally Posted by Vrso2 View Post
No error codes.
Possibility of fuel contamination I.E. water in the fuel. I would try to add one of the better fuel additives.
Here is a list of symptoms that one can find when water enters the gas or fuel tank.
Reduction in Car's Mileage. Water getting inside the car's gas tank can decrease the motor power gradually. ...
Sudden Stalling of Engine. ...
Engine Won't Start at All! ...
Trouble Accelerating the Car.
Ecate likes this.
post #13 of 36 Old 04-10-2019, 04:28 PM Thread Starter
Yes, ill try to pump out the gas...
but still...
It starts and than stalls...
I think, it would run rough but this run for a sec and than dies... looks more like electrical problem... some of the sensors went bad...
Too bad, there is no check engine light on.
Vrso2 is offline
post #14 of 36 Old 04-11-2019, 03:09 AM
Scuba's Avatar
Quoted: 12 Post(s)
I had a weird moment like this once i was driving down the road and the car whent into a limp mode for about a block and then died. Did something simular where itnwould kind of start then stall right out. I pulled all the fuses out (no test light on me) and after seeing they were all good i was upset. But then I just turned the key and it started havent had that problem since I dont know if this will help or not but I figure its worth a shot.
Scuba is offline
post #15 of 36 Old 04-11-2019, 05:14 AM Thread Starter
Which fuse box?
Vrso2 is offline
post #16 of 36 Old 04-11-2019, 01:40 PM
Quoted: 46 Post(s)
Yes, ill try to pump out the gas... J
but still...
Just add a can of "dry gas", UNLESS somebody pumped a diesel fuel, or there was some prank with putting sugar in the fuel tank.
post #17 of 36 Old 04-11-2019, 05:02 PM
Scuba's Avatar
Quoted: 12 Post(s)
The fuse box under the hood
Scuba is offline
post #18 of 36 Old 04-11-2019, 09:02 PM
Here's something crazy,
Can you unplug the MAF and try starting the car?
scarecrowdjinn is offline
post #19 of 36 Old 04-12-2019, 12:22 AM
Quoted: 84 Post(s)
I would be grilling the son about how car came to be that way, pretty uncommon to show up like that suddenly since you have already serviced the parts likely to have fixed a sudden issue.
If you have tried to start it enough the not running will positively wet the plugs out to then not start easy and die easy. Pull them to see if they are wet. Your perceived rich issue, ALL cars start rich but go to running fast enough to burn the plugs off clean, if they cannot run due to other reason the plugs quickly wet out. Then car only runs like crap for a second to die even if nothing is wrong with it. May need more plugs.
post #20 of 36 Old 04-12-2019, 03:07 AM Thread Starter
Same result with unpluged MAF....
Vrso2 is offline
Similar Threads
Engine starts but then stops gandrews General Versa Discussion 1 06-11-2016 10:34 AM
Won't start….starts and dies. dragongunner General Versa Discussion 2 05-12-2016 10:55 PM
Engine swap HR15DE Engine and MR20DE Engine Tiida868 Engine Forum 6 06-13-2013 12:35 AM
can you help me? engine almost stall viet510racer Engine Forum 9 01-22-2012 12:09 AM
noisy on cold starts? PIMking General Versa Discussion 7 12-03-2010 06:16 PM
