-   -   Engine starts and stall in 1-2 sec (https://www.nissanversaforums.com/general-versa-discussion/42886-engine-starts-stall-1-2-sec.html)
Vrso2 04-09-2019 11:54 AM
Hi group,
Trying to fix my sons 2007 versa. We bought it new for my wife and last few yers back become be a youngest son commuter.
Now...
Son towed car home and said, engine is stalling.
We replaced fuel pump, fuel filter, plugs and coils, crankshaft and camshaft position sensors. I cleaned TB and checked for vacuum leaks.
We have fuel coming to chambers and getting sparks on plugs.
Engine start for about 1-2 seconds and stall.
I out of the possible causes... anybody can help?
Thx
pimperell 04-09-2019 02:12 PM
Any codes showing up?? Mileage on the vehicle?? Possibility of fuel contamination??
scarecrowdjinn 04-09-2019 04:05 PM
This may be tough because it sounds like you fired the parts cannon at it, and could have inadvertently added additional problems.
1) Are there any code that you know of. With a light, or pending?
2) Do you have a scan tool can look at some of the PID's (car data)?
3) When you start the car, put your hand over the tail pipe, do you feel some good puffs of air coming out before it stalls?
4) Try a different key, maybe the chip in the key is flaking out or failing.
5) Was there any work, no matter how minor, that was done to the car shortly before the stalling started?
I'm agreeing with pimperell, and leaning towards some type of fuel issues.
You said you've replaced the fuel pump and fuel filter? Aren't the fuel pump and filter one unit for that year? I don't have an 07 so I might be making stuff up :)
Vrso2 04-09-2019 04:33 PM
No codes...
I will try secondary key, but car wouldnt start if there’s a problem with immobilizer.
I was thinking same way about diesel mixed with gas... aren’t diesel filing nozzle thicker so wont fit gas cars?
Car has around 100k.
Also, it has exhaust leak but after cat, somi don't think that could be a problem.
I think, when i started it last night after position sensors replacement, when engine was running for about a min at hi RPMs (about 2500), i could see a smoke coming out of the exhaust. So, i think, i was too rich of gas...
When im cranking without the plugs in ( have plug inserted to coil) i can see sparks and also, can see injectors spraying...
I did not changed fuel pump and filter, i have to double check that...
If there is two lines coming in to filter, which i think is also fuel pressure regulator, lines might be switched...
Vrso2 04-09-2019 04:51 PM
Hmmm, there is not much info online about versa...
it looks like fuel pump has fuel regulator and filter in same unit...grrrrr...
Ecate 04-09-2019 04:56 PM
Do you need the service manuals for a 2007 versa?
Ecate 04-09-2019 05:10 PM
I'm just leaving the link here for your 2007, in case you need them!
https://www.nicoclub.com/FSM/Versa/2007/hatch/
Here there is the whole car, just download the ones you need.
scarecrowdjinn 04-09-2019 08:05 PM
ok, so you now have the engine is now running, but at high rpms?
have you done a TB relearn procedure yet?
Vrso2 04-09-2019 08:46 PM
Not. I did not.
Engine started only once for that loooong minute 😉
Since than, im getting only second or two...
TechGuy8 04-09-2019 10:49 PM
Had you scan for error code?
You are wasting your money by keep changing parts without knowing where is the problem.
