How To: Add Cabin Air Filter to Versa Note and Versa Sedan - Page 4 - Nissan Versa Forums
 16Likes
post #31 of 98 Old 02-10-2015, 03:24 AM
Thanks for the info! I just checked my 15 s plus, had a filter in there, I pushed on it a little bit just to make sure Nissan didn't stick a piece of cardboard in there, felt behind it and could feel ridges and called it good. My buddy's 14 SV did not however, and we live in a dust-prone environment, awesome thread!!
Thed is offline
post #32 of 98 Old 02-15-2015, 10:09 AM
Here's the filter on the 2015... Part number is visible. I imagine you should be able to walk in and order it!
Thed is offline
post #33 of 98 Old 05-25-2015, 07:44 PM
Applies to 2012 Nissan Versa SV (Sedan) also
For the 2012 Versa SV Sedan, I discovered the same thing and so glad I found your forum post. O'Reilly brings up another filter Microguard #3718 which is TOO BIG... So I'll be swapping it for the Kia/Hyundai one listed; the video of the Sentra shows the exact same housing as on my 2012 Versa, only difference is that it's behind the glove box (not by the gas pedal) which is easy to remove after finding the right and left bottom tabs to open for the two hidden screws--total of 8 screws to remove.
Thanks again!
quintus is offline
post #34 of 98 Old 05-26-2015, 03:12 PM
Bill Berger's Avatar
I checked our 2015 Versa Note this a.m. before the wife went to work, and mine does, in fact, have it installed from the factory.
Thanks for the heads-up thread discussing this issue.
Bill Berger is offline
post #35 of 98 Old 05-30-2015, 04:21 PM
Childs Play's Avatar
Sweet. I'll have to add this.
Knowledge is knowing that a tomato is a fruit, but Wisdom is knowing not to put it in a fruit salad.
My Current Ride:
2014 Nissan Versa S+
My Past Rides:
2012 Camaro 2SS/RS M6 w/Corsa Cat Back Exhaust, CAI intake and Kooks Headers
2012 Camaro ZL1 A6
2002 Honda Insight
Childs Play is offline
post #36 of 98 Old 05-31-2015, 12:06 AM
Just a note. I went to o'reilly auto parts and asked them what they had for a 2014 Nissan Versa Sedan. They gave me a MicroGard 3713.
It didn't fit directly but I cut off part of it and it fit. (I have to admit that I accidentally broke it trying to push it in so then I trimmed it.)
Unfortunately it leaves a slight gap up top. But I started the car up and ran the AC for a while to see if it leaked. It didn't.
I don't really recommend this filter since it didn't fit 100% perfectly but it was only $16.49 so I'm leaving it in. (Also since I broke it I'm stuck with it.)
Maybe it would work better for the Note..?
Also once it's in it has its own seal around it so you can't attach the cover back over it.
This was a bit longer post than I meant to make it but just giving a heads up for this one. It's also a strange looking filter.
My Current Ride:
My Past Rides:
2012 Camaro ZL1 A6
2002 Honda Insight
post #37 of 98 Old 05-31-2015, 12:24 AM Thread Starter
jas32's Avatar
Quoted: 151 Post(s)
Child's Play, based on input from forum members and my own research, NONE of the parts stores (Oreiley, Autozone, Advance, RockAuto. Amazon, etc) lists the proper part for the 2013-2015 Nissan Versa Sedan/Note cabin filter. I myself bought the one from Amazon and they sent me the part that you show on your picture which did not fit.
If you go by the part numbers listed on the page 1 of this tread, everyone who done so seem to have achieved success.
2014 Versa Note SV
jas32 is offline
post #38 of 98 Old 06-27-2015, 05:21 PM
JohnVNote14's Avatar
Thank you so much for this thread! Just took delivery of a 2014 Note SV yesterday and installed the filter this morning. Took a little blind stumbling to get the door back on, but works well and I'm very happy.
JohnVNote14 is offline
post #39 of 98 Old 06-27-2015, 11:27 PM Thread Starter
jas32's Avatar
Quoted: 151 Post(s)
After you've done it a couple of times, replacing the door is fairly easy. Just make sure the top is properly located and secure (on its hook) then push the bottom pushed towards the filter and it should lock in place.
2014 Versa Note SV
jas32 is offline
post #40 of 98 Old 03-04-2016, 09:07 PM
qorray1968's Avatar
Quoted: 22 Post(s)
Just checked my 2015 Note S and mine has the cabin air filter installed, Nissan part # 27277 1kk0a.
qorray1968 is offline
