How To: Add Cabin Air Filter to Versa Note and Versa Sedan - Page 6 - Nissan Versa Forums
 16Likes
post #51 of 98 Old 05-23-2016, 08:00 AM
Notarized's Avatar
Quoted: 14 Post(s)
Originally Posted by jas32 View Post
I've had filters installed for 2 years now and haven't had a moisture problem. Of course I live in Michigan so conditions are different. However it also gets hot and humid here in the summer.
I wonder if you have a clogged A/C system drain problem?
Also, was the filter moist when you took it out? Just curious.
I had the dealership remove it, so I don't know if it was moist or not. I should have checked. The smell is starting to come back, so I probably need to have the dealer check and see if the drainage holes are draining properly. The dealership where I bought the car has a horrible service department. I have started taking it across town to a different dealer for service, they seem better, but I haven't asked them about this particular issue yet.
Thanks for the advice!
________________________
2015 MT Versa Note S
Notarized is offline
post #52 of 98 Old 05-25-2016, 01:25 AM
Originally Posted by Notarized View Post
FWIW, I removed the factory installed cabin air filter from my 2015 Note.
It was causing excess moisture to build up in the ducts, causing mold and mildew and the car was starting to stink.
I did an anti-mold duct flush last fall, and that helped, but the stink came back as soon as the weather started warming up.
Removed the air filter, flushed the ducts with anti-mold spray, and now the smell is gone.
I suspect the reason that many Versas didn't ship with the cabin air filters installed is because Nissan knows about the mildew problem building up in the ducts.
For those whose Versas did not come with the cabin air filter pre-installed, you might want to assess whether you're throwing money at a non-existent problem, or possibly, spending money to create one.
Can you please tell what kind of spray you used and how to do it as I guess I have the same issue.
Thanks
RaahPatel is offline
post #53 of 98 Old 05-25-2016, 04:51 AM
Quoted: 7 Post(s)
No way in Hell I'd add a cabin air filter to my Note, the poor HVAC blower struggles to move enough air as it is.
...or maybe my car has one and I should take it out. Hmm.
Notarized likes this.
Master0fMadness is offline
post #54 of 98 Old 05-25-2016, 07:25 AM
Notarized's Avatar
Quoted: 14 Post(s)
Thanks
This is what I did:
https://www.youtube.com/watch?v=VrVc_FXrbHY
post #55 of 98 Old 05-29-2016, 07:34 AM
TKO
Quoted: 15 Post(s)
I have a 2014 Versa Note S+. I bought a filter from Glendale Nissan here in Glendale, California, last October. The filter that they gave me was the one that they have listed for the 2012 Versa sedan, part #999M1-VS007. I put it in my car but it was too big; even when I squished it to fit it through the opening, it bulged out of the opening. I took it back to the dealer but they insisted that it is the right filter. They told me that their service department uses that filter part number when they install filters for Versa Notes; they said to just stuff it in.
Well, I put it in again. It still bulged out of the opening but I shoved it in there and placed the door/cover back in place. It's been running in there ever since. I'll leave it in there until it hits 45,000 miles; it had about 30,000 miles when I put it in. If the filter is dirty by then, then I'll know that it filtered at least some of the dirt/contaminants in the air.
Originally Posted by POSinCarlsbad View Post
Compliments to the OP for the research. Must say though that a few of the named filters' dimensions DO NOT match the dimensions for the 2015.
I removed my filter (27277 1KK0A) and the dimensions were 7.97" x 9.03". Being that I had to contort it to remove it, I'd give or take 0.10"
A few of the filters listed, per the manufacturer specs are off by 0.25" or more. When you're talking air filtration, that is not good. Just because something fits "in" something doesn't mean they're perfect match... For example, a Les Paul will "fit" into a P-Bass case but, if you were to carry it to a gig, there's a decent chance that you'll open the case to a broken-necked guitar.
As I mentioned above, filter part #999M1-VS007 is not a perfect fit in the compartment. This means that air can possibly flow around the filter rather than through it. Just because it can be stuffed in there doesn't mean that it's a perfect fit. It's too bad that people have their Versa sedans/Versa Notes serviced at this dealership and that they don't know that the filter is not a perfect fit.
Also, some people have mentioned that their 2015 Versa (Note) has a filter already installed when they purchased their car brand new. The filter part # is 27277 1KK0A. Last September/October, I went to a couple local dealerships (Surf City Nissan in Huntington Beach, CA, and Glendale Nissan) and they did not carry this part. This is why I bought the 999M1-VS007 instead.
TKO is offline
post #56 of 98 Old 05-30-2016, 09:46 PM Thread Starter
jas32's Avatar
Quoted: 151 Post(s)
I just replaced my cabin filter 2 weeks ago since my car turned 2 years old and it is bone dry, no moisture whatsoever.
2014 Versa Note SV
jas32 is offline
post #57 of 98 Old 05-30-2016, 10:00 PM Thread Starter
jas32's Avatar
Quoted: 151 Post(s)
Originally Posted by TKO View Post
....Well, I put it in again. It still bulged out of the opening but I shoved it in there and placed the door/cover back in place. It's been running in there ever since. I'll leave it in there until it hits 45,000 miles; it had about 30,000 miles when I put it in. If the filter is dirty by then, then I'll know that it filtered at least some of the dirt/contaminants in the air.
As mentioned in the quote above, filter part #999M1-VS007 is not a perfect fit in the compartment. This means that air can possibly flow around the filter rather than through it. Just because it can be stuffed in there doesn't mean that it's a perfect fit. I feel for people who had their cars serviced at this dealership and whether they know that the filter is not a perfect fit.
I've used this one successfully for the past 2 years on my 2014 Note sourced from AMZ, about 1/2 price of the OEM filter:
Amazon.com: ATP CF-102 White Cabin Air Filter: Automotive Amazon.com: ATP CF-102 White Cabin Air Filter: Automotive
I know for sure it fits and works since has evidence of trapped dust and debris when I take it out.
2014 Versa Note SV
jas32 is offline
post #58 of 98 Old 05-30-2016, 10:10 PM Thread Starter
jas32's Avatar
Quoted: 151 Post(s)
If you have a late 2015 Note, chances are you have a filter installed.
I was actually expecting a significant drop in airflow after I installed a filter (after I experienced it when I installed a filter on my Jeep), but to my surprise, I hardly noticed the difference.
My AC performance is fairly adequate. I'm more PO'd about the unsatisfactory heater performance which is inadequate in snow belt states. To me blower volume output is OK.
2014 Versa Note SV
jas32 is offline
post #59 of 98 Old 06-14-2016, 06:53 PM
2013Versa's Avatar
FRAM part number for Versa cabin filter
FRAM
Here is a link for the cabin filter CF10545 for our Versas.
2016 Versa Note
1.6 5 speed
Cayenne Red (NAH)
2013Versa is offline
post #60 of 98 Old 06-18-2016, 04:19 PM
Quoted: 7 Post(s)
Originally Posted by 2013Versa View Post
FRAM
Are you a 2013 Versa owner as your screen name indicates or are you a 2015 Versa Note owner as your signature states?
That filter pictured does not fit in the 2015 Versa Note SV that I own. I had it and ended up returning it. That is what Napa had on their computer as the compatible filter... In fact, an employee had the 2015 V Note SR and we all went back and the manager (who was going to charge me a 20% restock fee) waived it when he saw how impossible it was to put in the slot.
By the way, All glories to Bob.
Last edited by POSinCarlsbad; 06-18-2016 at 04:21 PM. Reason: Added more about the incorrect filter linked for 2015 models.
POSinCarlsbad is offline
