How To: Idle Air Volume Learning (Easy Way) - Nissan Versa Forums
 4Likes
  • 2 Post By Poptech
  • 1 Post By jasonkg
  • 1 Post By JoshG
post #1 of 7 Old 11-24-2014, 02:06 PM Thread Starter
Poptech's Avatar
Anytime the Electric Throttle Control Actuator (Throttle Body) or ECU is disconnected from the wiring harness, the idle speed will need to be re-learned. This procedure can also resolve a high idle at park or in neutral of over 1500 RPM and a pulsating idle that goes high and drops low repeatedly. The idle for the Nissan Versa should be between 650-750 RPM at park or in neutral. The official procedure can be found here; however, I found that this procedure is very time sensitive and it was much easier to perform it the following way.
Tools:
* Stop Watch or Stop Watch App for Smartphone
Preparation:
1. Drive Versa for 10 minutes to warm up the engine and transmission.
2. Turn off Air Conditioning, Headlamps and Rear Window Defogger.
3. Put Versa in park, straighten out steering wheel (neutral position) and turn off vehicle.
Procedure:
* The following procedures are time sensitive and if messed up, must be started from the beginning. It may take a few tries to get it right.
1. Turn the ignition switch (key) to the off position and wait 10 seconds.
2. Turn the ignition switch (key) to the on position and start the stop watch at the same time. (The on position is the second click)
3. At 3 seconds on the stop watch, press the accelerator pedal fully to the floor and fully release it 5 times before the stop watch gets to 8 seconds. (Timing wise, all that matters is it gets done 5 times between 3 and 8 seconds on the stop watch)
4. At 15 seconds on the stop watch, press the accelerator pedal fully to the floor and hold it down.
5. At 35 seconds on the stop watch, fully release the accelerator pedal and then immediately start the engine.
6. At 60 seconds on the stop watch, rev up the engine 2-3 times and make sure each time the tachometer falls back down to 650-750 RPM.
7. Turn the ignition switch (key) to the off position - idle is now set.
JoshG and kat_hat like this.
Poptech is offline
post #2 of 7 Old 12-09-2015, 01:46 AM
Thanks PopTech, I just got the P0507 CEL today, so I'm going to clean the throttle body and perform the relearn procedure. I appreciate the summarized version.
jasonkg is offline
post #3 of 7 Old 12-09-2015, 04:18 PM
I performed this procedure today and it worked like a champ. It cleared the P0507 code as expected. Thanks Again Poptech.
kat_hat likes this.
jasonkg is offline
post #4 of 7 Old 12-12-2015, 06:12 AM
JoshG's Avatar
Quoted: 90 Post(s)
Great how-to, thanks Poptech.
kat_hat likes this.
2010 NISSAN VERSA 1.6
1991 MAZDA B2600i
JoshG is offline
post #5 of 7 Old 10-03-2018, 10:46 AM
I performed this recently and the "Service Engine Soon" light began blinking erratically. I turned the car off, pulled the ECU fuse, put it back in, and it went back to just being solid.
Anyone else have this happen?
Soltis187 is offline
post #6 of 7 Old 10-03-2018, 09:11 PM
Quoted: 44 Post(s)
I guess it is a time to disconnect NEG battery terminal for a few minutes, and then to drive for a while.
post #7 of 7 Old 01-28-2019, 12:39 PM
I have a 2007 hatchback with 101k miles. I changed the spark plugs last month and have had this coffee since . I've tried the relearn several times with no improvement. Bought a used throttle body to try for fun with the same issue. I've had a mechanic tell me to replace the first pump because this will also improve the bad mpg. (I get about 30) what should I do next? Tx, Bill
schimmerb is offline
idle , idle air volume learning
