-   -   How to: Replacing hubs and rotors. (https://www.nissanversaforums.com/how-tos/3897-how-replacing-hubs-rotors.html)
bigdaddychia 12-08-2011 02:16 PM
So I figure I would actually post a how to. I decided that with 300k it might be a wise choice to replace the hubs and fionally replace the rotors(they were warping). So I found some good replacments. First I discovered a company called Disc Brake Rotors & Pads | R1Concepts.com that sales only brake stuff. So I purchased there e-line slotted and cross-drilled rotors and ceramic brake pads. I then found that timken has replacemtn hubs and found a new set on ebay for 60 a peice. Autozone wanted a 100 and the dealaer wanted 150. Note, this is for 1st generation but 2nd should be similar. So here we go.
First u need to remove the cotter pin on the axle and with some one putting the brakes on loosen the axle nut. U will need a 30mm axle nut socket to do this
next with a 14mm socket remove the 2 bolts holding the caliper to the caliper bracket. U can either use a wire to hang the caliper or it actually can fit in between the springs as not to pull on the brake line.
http://i256.photobucket.com/albums/h...204_161400.jpg
http://i256.photobucket.com/albums/h...204_161556.jpg
Next with a 17mm socket take off the caliper bracket
http://i256.photobucket.com/albums/h...204_161627.jpg
Take the rotor off and this is what you should see
http://i256.photobucket.com/albums/h...204_161700.jpg
Now for the hub removal. With a 21 mm socket and open end wrench take off the 2 bolts holding the shock to the spindle
http://i256.photobucket.com/albums/h...204_161732.jpg
http://i256.photobucket.com/albums/h...204_161804.jpg
Next taking a soft rubber mallet hit the threaded end of the axle and it will back out of the hub. You may need a center punch or flat had screw driver to knock it all the way thorugh.
http://i256.photobucket.com/albums/h...204_161926.jpg
Taking a 17 mm socket remove the 2 bolts holding the hub to the spindle
http://i256.photobucket.com/albums/h...204_161951.jpg
Take a hammer and pound the old hub out.
New Hub next to old hub
http://i256.photobucket.com/albums/h...204_162023.jpg
new rotor next to old rotor with 307k miles on them
http://i256.photobucket.com/albums/h...204_162636.jpg
Mount the hub back to the spindle and tighten the bolts down. Now just do everything in the reverse order and u should end up with this.
http://i256.photobucket.com/albums/h...204_163358.jpg
A tip for the pads. Replace them like in this pic. Put the pads on first colpase the caliper then put the caliper on
http://i256.photobucket.com/albums/h...204_163646.jpg
And now done with wheels back on
http://i256.photobucket.com/albums/h...204_164510.jpg
So far I have been very happy. All the brake squeal is gone and so is the shakign from when I stop. Total price on this job
160 for pads and rotors
120 for hubs
14 for 30 mm axle nut socket
robj80 12-08-2011 02:36 PM
Awesome post. So I guess the hub and bearing are one unit on the Versa? With getting so many miles out of the stock parts I'm surprised you bought anything else.
bigdaddychia 12-08-2011 02:48 PM
Well I trust timken. They make quality parts. And I have had good luck with after market stuff as well. And yeah the hubs and bearings are a non servicable unit
JoshG 12-08-2011 02:58 PM
Upgrading performance parts with quality parts is always good. Nice wheels too. :thumb2:
hemifan87 12-08-2011 03:43 PM
very nice how-to thats amazing you got all those miles out of the parts
MizuShinobi303 12-08-2011 05:33 PM
Very informative I am looking forward to the 300K mark. How difficult would it be to swap out the drum breaks for performance rotors?
bboy_romeo 12-08-2011 08:17 PM
very nice, i'd be scared to do that myself lol i would probably take it all apart and then forget how to put it all back lolll
bigdaddychia 12-09-2011 01:36 AM
im a self taught mechanic. It only took maybe 2 hours total and i caould knock it out in an hour the next time i do have to do it. Probably gonna be replacing my cats and o2 sensors soon so waith till u see that write up
robj80 12-09-2011 04:11 AM
You are an asset to the community. Can't wait until I need to do some work so I can do another howto. Next for me will prob be coolant drain and fill then sparkplugs.
BluV3R18 12-09-2011 06:30 AM
very nice write up, pics and everything good job!!!
I hope mine makes it to 300,000 miles too =)
