How to: Replacing hubs and rotors. - Nissan Versa Forums
post #1 of 19 Old 12-08-2011, 02:16 PM Thread Starter
So I figure I would actually post a how to. I decided that with 300k it might be a wise choice to replace the hubs and fionally replace the rotors(they were warping). So I found some good replacments. First I discovered a company called Disc Brake Rotors & Pads | R1Concepts.com that sales only brake stuff. So I purchased there e-line slotted and cross-drilled rotors and ceramic brake pads. I then found that timken has replacemtn hubs and found a new set on ebay for 60 a peice. Autozone wanted a 100 and the dealaer wanted 150. Note, this is for 1st generation but 2nd should be similar. So here we go.
First u need to remove the cotter pin on the axle and with some one putting the brakes on loosen the axle nut. U will need a 30mm axle nut socket to do this
next with a 14mm socket remove the 2 bolts holding the caliper to the caliper bracket. U can either use a wire to hang the caliper or it actually can fit in between the springs as not to pull on the brake line.
Next with a 17mm socket take off the caliper bracket
Take the rotor off and this is what you should see
Now for the hub removal. With a 21 mm socket and open end wrench take off the 2 bolts holding the shock to the spindle
Next taking a soft rubber mallet hit the threaded end of the axle and it will back out of the hub. You may need a center punch or flat had screw driver to knock it all the way thorugh.
Taking a 17 mm socket remove the 2 bolts holding the hub to the spindle
Take a hammer and pound the old hub out.
New Hub next to old hub
new rotor next to old rotor with 307k miles on them
Mount the hub back to the spindle and tighten the bolts down. Now just do everything in the reverse order and u should end up with this.
A tip for the pads. Replace them like in this pic. Put the pads on first colpase the caliper then put the caliper on
And now done with wheels back on
So far I have been very happy. All the brake squeal is gone and so is the shakign from when I stop. Total price on this job
160 for pads and rotors
120 for hubs
14 for 30 mm axle nut socket
bigdaddychia is offline
post #2 of 19 Old 12-08-2011, 02:36 PM
Awesome post. So I guess the hub and bearing are one unit on the Versa? With getting so many miles out of the stock parts I'm surprised you bought anything else.
post #3 of 19 Old 12-08-2011, 02:48 PM Thread Starter
Well I trust timken. They make quality parts. And I have had good luck with after market stuff as well. And yeah the hubs and bearings are a non servicable unit
post #4 of 19 Old 12-08-2011, 02:58 PM
JoshG's Avatar
Quoted: 90 Post(s)
Upgrading performance parts with quality parts is always good. Nice wheels too.
2010 NISSAN VERSA 1.6
1991 MAZDA B2600i
JoshG is offline
post #5 of 19 Old 12-08-2011, 03:43 PM
hemifan87's Avatar
very nice how-to thats amazing you got all those miles out of the parts
project Black Widow
https://www.nissanversaforums.com/showthread.php?t=2313
Project 200sx
https://www.nissanversaforums.com/non...w-old-car.html
ΜΟΛΩΝ ΛΑΒΕ
hemifan87 is offline
post #6 of 19 Old 12-08-2011, 05:33 PM
MizuShinobi303's Avatar
Very informative I am looking forward to the 300K mark. How difficult would it be to swap out the drum breaks for performance rotors?
Nissan Versa HB 6MT 1.8L I4 Magnetic Grey
MizuShinobi303 is offline
post #7 of 19 Old 12-08-2011, 08:17 PM
bboy_romeo's Avatar
very nice, i'd be scared to do that myself lol i would probably take it all apart and then forget how to put it all back lolll
- 6000k Bi-Xenon HID's, Custom Catback w/ Magnaflow muffler, AEM CAI, Tanabe SUSTEC NF210 Lowering Springs, Tanabe Strut Tower Brace, Ultra Racing Rear Shock Tower Brace, 17" Konig x906 Black Wheels w/ Falken tires 205/45/17, JVC KD-R208 deck w/ Kenwood amp and 10" Energy Sub, blue interior painted, 3 piece mesh grille, debaged, tinted tails, versa 3rd brake light decal, vortex roof spikes, window visors etc..
bboy_romeo is offline
post #8 of 19 Old 12-09-2011, 01:36 AM Thread Starter
im a self taught mechanic. It only took maybe 2 hours total and i caould knock it out in an hour the next time i do have to do it. Probably gonna be replacing my cats and o2 sensors soon so waith till u see that write up
post #9 of 19 Old 12-09-2011, 04:11 AM
You are an asset to the community. Can't wait until I need to do some work so I can do another howto. Next for me will prob be coolant drain and fill then sparkplugs.
post #10 of 19 Old 12-09-2011, 06:30 AM
very nice write up, pics and everything good job!!!
I hope mine makes it to 300,000 miles too =)
2007 HB 6spd manual Previous
2014 Nissan Sentra Current
BluV3R18 is offline
