Replace Nissan Versa Engine Coolant 2014 - Nissan Versa Forums
  • 1 Post By whicky1978
post #1 of 5 Old 06-24-2018, 01:57 PM Thread Starter
whicky1978's Avatar
Quoted: 8 Post(s)
I did a simple drain and replace at 87K miles. You will find the butterfly petcock on bottom left of the radiater. I opened it up and let it drain into a bucket. My coolant resovoir was empty 😶 so I did not empty it. Once drained I topped it of and burped it with the radiator cap off. I drained a half gallon and added a whole gallon back in. some of the old coolant would’ve still been left in the block so if you say this in a probably be best to replace it more often. I understand there should actually be 2 gallons in all. i’m not a mechanic so take this with a grain of salt. FYI i found it difficult to pull out the radiator hose and decided to leave it. Blue Coolant supposed to be good for 105K. Personally I worry about leaving water in the engine block with the flush and diluting the coolant that’s added.
By the way it’s a messy if you don’t use a tube to when you drain.
Here is a full flush tutorial.
https://www.carcarekiosk.com/video/2.../flush_coolant
whicky1978 is offline
post #2 of 5 Old 06-24-2018, 03:52 PM
I like to fill it with water and a bottle of flush per directions, then flush a second time, drain and fill.
post #3 of 5 Old 07-14-2018, 12:35 PM Thread Starter
whicky1978's Avatar
Quoted: 8 Post(s)
Update. I had to add more to the coolant tank a couple weeks latet but now it’s staying at max. i’m getting Hydro meter to see how it test out of the jug and compare to my car.
post #4 of 5 Old 07-15-2018, 01:31 AM
With this warm spring and summer its likely the water in the coolant has evaporated making it lower then normal so you had to add some.
post #5 of 5 Old 07-17-2018, 04:38 PM Thread Starter
whicky1978's Avatar
Quoted: 8 Post(s)
I tested the nissan coolant in the jug wifh a hydrometer and it maxed it maxed out the scale.
Cobb likes this.
