Nissan Versa 2014 Manual Transmission Fluid Change - Nissan Versa Forums
  • 1 Post By whicky1978
post #1 of 5 Old 06-24-2018, 02:12 PM Thread Starter
whicky1978's Avatar
Quoted: 8 Post(s)
You will need an 8mm square head ratchet. You can by the 8 mm and 10 mm Amazon.
I used the Nissan 75w 85 OEM MTF. I understand Royal Purple synthetic is excellent too. You will need nearly 3 quarts
You will also need the hand pump
to pump the new MTF in through the fill plug. Make sure you can remove the plastic butterfly fill plug before you drain. Surprisingly neither the fill plug nor the drain plug we’re on too tight.
I think Nissan recommends this be changed out at 60,000 miles.
In someways this was easier than an oil change most of the work is pumping the MTF fluid. I’m not a mechanic so take this with a grain of salt.
ID:	14034   Click image for larger version
ID:	14036   Click image for larger version
ID:	14038   Click image for larger version
ID:	14040   Click image for larger version
whicky1978 is offline
post #2 of 5 Old 06-24-2018, 02:15 PM Thread Starter
whicky1978's Avatar
Quoted: 8 Post(s)
You keep pumping until it starts to spill back out.
Cobb likes this.
post #3 of 5 Old 08-11-2018, 07:11 AM
Nissan Versa 2014 Manu laal Transmission Fluid Change
What type of tool did you use to remove the filler screw.
Thank you
Orlando Acosta is offline
post #4 of 5 Old 09-07-2018, 01:58 PM Thread Starter
whicky1978's Avatar
Quoted: 8 Post(s)
Thank you
Mine was plastic so I turned it by hand if I recall. Maybe you can post a picture here of yours?
post #5 of 5 Old 10-03-2018, 07:41 PM
gpalmos's Avatar
Just Replaced Manual Transmission Fluid on my 2016 Versa S @ 76,500 miles.
Used Red Line MT-85 75W85 GL-4 Manual Transaxle Lubricant. Took slightly less than 3 Quarts. It is a full synthetic.
Replaced both plugs and both washers.
Old Fuid still looked pretty good.
I'll update with performance difference in the future.
gpalmos is offline
