-   -   Aftermarket fuel regulator (https://www.nissanversaforums.com/how-tos/42076-aftermarket-fuel-regulator.html)
Noe Morals 07-09-2018 04:43 AM
Hey had a quick question I’m wanting to install a adjustable fuel pressure regulator on my 08 Versa but how do I do this when the current one is in the tank?
pimperell 07-09-2018 10:15 AM
Originally Posted by Noe Morals (Post 283974)
Hey had a quick question Iím wanting to install a adjustable fuel pressure regulator on my 08 Versa but how do I do this when the current one is in the tank?
Knowing the reason for installing an adjustable fuel pressure regulator might give members the information they need to give you an answer.
Noe Morals 07-09-2018 03:23 PM
I’m wanting to install a aftermarket regulator cause I got a 255 lph fuel pump but it won’t work properly without the right regulator
Cobb 07-09-2018 06:36 PM
You should replace the fuel pump as its not likely its going to be able to fuel larger injectors under boost for an extended amount of time and maintain psi. Im assuming you are doing forced induction? >:D
Noe Morals 07-10-2018 12:06 AM
Eventually but what should I do now about this regulator
Cobb 07-10-2018 02:23 PM
Good question. Maybe best to wait til you can do it at once. I know for super chargers you can build the build and leave the belt off the screw til you are ready to pull the trigger, get it tuned, etc. Turbos I guess you can leave the waste gate open and blow off?
