-   -   How to: Programming key fob(TIIDA only...NOT VERSA) (https://www.nissanversaforums.com/how-tos/9017-how-programming-key-fob-tiida-only-not-versa.html)
arturorv00 11-20-2014 03:02 PM
Originally Posted by nissantiida (Post 189986)
Yes i think you can. try
Yes actually, I already did it :)
Thanks
hero24631 05-19-2015 02:29 AM
I have tried many times, but it didn't work.
My car is nissan tiida 2006. Can you help me?
Ivy Xia 10-06-2015 08:58 AM
Hi,
I have a Tiida 2007, and I lost my car key TAT. Where did you guys bought the blank key fob? Thanks a lot.
hero24631 10-22-2015 01:24 AM
Originally Posted by Ivy Xia (Post 220834)
Hi,
Last time I bought it from Amazon. Remote you can make it by your self, however Key you can not make it unless you have program device make it.
seany 11-24-2015 01:25 PM
How to Programremote for Nissan Tiida
I have a 2006 Japanese Nissan Tiida with anti theft system. I bought the 3 in 1 remote but can't get it program. How do I program this remote. What is the frequency of the remote for a 2006 Japanese Nissan Tiida?
Jakes Sovee 02-14-2016 10:23 AM
ignition wont turn on
i tried using the insert key six times technique but my light is still flashing and my cars ignition wont move from off to any other position, and the steering isn't locked either, can someone assist me with this, btw i own a nissan tiida
Vik Rughoobur 08-25-2016 10:47 AM
Originally Posted by nissantiida (Post 98681)
Since i have a tiida I spent so much time researching a way to program my remote and i finally got the solution. Tiida key fob programming is different than versa(dont know why).
1. Close all doors.
2. Lock doors with drivers side power door lock switch.
3. Insert and withdraw the key 6 times. Doors should UNLOCK.
4. Turn Key to accessory position.
5. Lock doors with driverís side door lock switch.
6. Press button on remote control.
7. Remove Key.
Hi, I tried the steps till nį3, but my doors don't UNLOCK after step 3.
I tried several times but no luck :(
Anyone else had this issue ?
I have a Tiida Latio year 2005 btw.
Thanks in advance.
awahou 01-31-2017 06:32 AM
Hi there, I am new to the forum so unsure how this works. I have an 07 Nissan Tiida Axis Autech (ex Japan) imported into my home country of New Zealand. I bought it with no Key Fobs - only one standard key. I have tried to programme several after market key fobs for the car but nothing works. The car does go into programming mode after inserting and removing the key six times and does seem to be set up for keyless entry, but I am unsure of the frequency of the fob I should be trying to programme (i.e. is it 315mHz, 433 mHz or 434 mHz?). Has anyone got an ex-Japan Tiida Axis Autech out there who could photograph the code on the back of their fob (that works) and either post it here or send it to me as message? Thanks!!!
Ashleigh Beer 06-04-2017 11:18 PM
2005 Tiida keyless entry
I have recently bought a 2005 Nissan Tiida second hand.
The lady selling to me has said there are issues with the keyless entry. The car is locked/unlocked via. A smaller key, which to turn on the car is inserted into the keyless ignition to start like normal.
I am wanting to purchase an immobiliser/alarm remote to lock/unlock the car without using a key.
How would I go about purchasing this?
ravin 06-21-2017 11:40 PM
I have a Nissan Tiida 2005 I lost my remote can someone advise me the right frequency for the remote. Do we have to cut the key with the remote we want to program into the ignition or the transponder key will do? I am programming the remote but have not cut the key but using another key that starts my car.
