-   -   How to: Programming key fob(TIIDA only...NOT VERSA) (https://www.nissanversaforums.com/how-tos/9017-how-programming-key-fob-tiida-only-not-versa.html)
nissantiida 06-08-2013 04:10 PM
Since i have a tiida I spent so much time researching a way to program my remote and i finally got the solution. Tiida key fob programming is different than versa(dont know why).
1. Close all doors.
2. Lock doors with drivers side power door lock switch.
3. Insert and withdraw the key 6 times. Doors should UNLOCK.
4. Turn Key to accessory position.
5. Lock doors with driverís side door lock switch.
6. Press button on remote control.
7. Remove Key.
sgvaibhav 06-08-2013 06:35 PM
thanks.
admins - this can be moved in how-to section so everyone can know.
32junky 07-05-2013 07:05 AM
Hi I have a 2004 Tiida, (a Japanese import to New Zealand) and have lost my key fob, a 2 button lock/unlock one. Does anyone know the frequency of the fob transmitter, I have obtained one that looks very like the old one and the key blank pattern is the same, the information on the fob is 5WK4 876/819. 433MHz. I have followed the very welcome recent post on programming and the doors unlock on the sixth key removal but the fob simply is not working. The battery (3V) is fine. Any ideas ? I am suspicious of the frequency. No joy from the dealer, at least $250 for a new fob. Car works well on a plain key.
nissantiida 07-06-2013 12:01 AM
I bought this and worked on my nissan tiida perfectly
New Replacement Nissan Infiniti Key Fob Keyless Entry Remote Clicker KBRASTU15 | eBay
32junky 07-06-2013 06:05 AM
HI Thanks for the rapid reply, I am not sure if I am getting into the program mode, on the sixth key withdrawal the doors unlock ok but when putting key back and turning to Acc. and locking the door again, nothing happens, no hazard lights or anything. I have tried variations on the sequence but nothing. Is this ok?? Thanks for the link, I see they will ship to New Zealand.
nissantiida 07-06-2013 08:34 PM
The Nissan tiida does not flash hazards that's the difference between it and the versa
and when the doors unlock switch the key to acc then lock the doors then press any botton on the remote
32junky 07-07-2013 09:23 AM
Thanks for that, have not yet succeeded with my 433MHz fob , will await fob from your link. thank you.
iridefast 08-11-2013 12:18 PM
This worked great for my 2008 Versa. Thx for the info. Only difference is after the 6 key inserts, my hazards flashed once, instead of the doors unlocking. Everything else worked the same. Thank you.
arturorv00 10-24-2014 04:53 AM
Hi guys,
I had a Tiida 2008, I sold it and I kept one of the two fob then I bought another Tiida 2007, do you know if I can program the 2008 fob on my 2007?
nissantiida 11-13-2014 09:29 AM
Originally Posted by arturorv00 (Post 187266)
Hi guys,
Yes i think you can. try
