2016 Versa SV radio swap - BT buttons and mic don't work - Page 3 - Nissan Versa Forums
 5Likes
post #21 of 40 Old 07-06-2018, 03:37 AM
Versa15's Avatar
If I'm installing a 2016 Sentra Display Color unit into a 2015 Versa SV with the base radio, is the 2014 base and Display Audio wiring diagrams correct for me? There all I can find. It's the AUX, MIC, and Camera inputs I'm trying to connect.
(Edit: July 31, 2018
No, the 2014 Base Audio wiring diagram was not correct for me. I'm starting out with Mid Level Audio. The 20 pin connector remains unchanged. The 32 pin has several changes listed in following post below.)
I may not do the camera for a while. But I don't like the aftermarket camera I have. Looks straight to the ground.
I've ordered the AXXESS add camera wire connectors, to build a plug n play to correct the AUX and MIC.
Versa15 is offline
post #22 of 40 Old 07-07-2018, 11:44 AM
Sorry bro, I dont know. I did buy the manual and have it on my chromebook somewhere. If you can or are willing to PM me an email address Ill see if I can send you some screen shots.
I have had success with getting the honda dealer to print off stuff for a car I had. Ironically the parts dept was the most helpful with that.
Id like to learn more about the bluetooth module that guy showed you can upgrade to use with aftermarket radios and maintain steering wheel controls. Ive held off putting a carplay radio in my car due to that and crutchfield says they do not make a module for nissans.
Im in the middle of moving and severe back pain.
post #23 of 40 Old 07-08-2018, 11:12 AM
Versa15's Avatar
I've had two back surgeries. My tailbone, L4, and L5 (S1) are all fused together now.
Versa15 is offline
post #24 of 40 Old 07-09-2018, 06:42 PM
Thx and thanks.
Ive seen doctors, they say the back pain is in my head. I see people who run those massage kiosk in the mall who do not even speak english. Some how they seem to know where and how to work the painful areas to make them better.
Ive had more x rays, nuclear bone scans, etc. One time I had a compression fracture of my l4 another time I had an angihemitona(SP?) in the same area as my pain, but the docs say its nothing.
post #25 of 40 Old 07-14-2018, 05:36 AM
Versa15's Avatar
Originally Posted by tomiga View Post
As a bit of an update, I found that it looks like I'll be able to get the hands-free system at least partially working. Using info I found online and verifying it with the service manuals, it appears that if I disconnect the Bluetooth module and connect the following pins on the connector, I should at least have all of the steering wheel controls working:
Pin 12 -> Pin 17
Pin 13 -> Pin 18
Pin 14 -> Pin 19
As I guessed, the Bluetooth module IS intercepting the steering wheel controls partially.
Because my Versa is still under warranty, I didn't want to alter the wiring were I couldn't quickly reverse it back to Base Audio head unit.
I bought the PAC BT-SWC-NI1 connector that simply jumps the wire pin positions.
It does exactly what tomiga has listed. 12 to 17, 13 to 18, and 14 to 19. So this is all one would need to forward the talk switch controls to an aftermarket head unit. I assume most aftermarket units with handsfree talk will have their own mic, either built in or external.
So far no one seems to be able to hear me when using the Bluetooth handsfree. So even after the upgrade oem radio goes in, I may have to look into a different mic setup too. Not sure if it's the placement in the ceiling pointing straight down? My 2012 Venza had mic in lower part of the rear view mirror, so it pointed toward my face. People I talked to said they couldn't tell I was using handsfree, it was so clear. I may keep an eye out for a Toyota Venza mirror.
My Display Color Audio head unit has an 8 pin connector that I think I need that my Versa SV Base Audio doesn't have. Maybe I can find one in a junk yard.
Versa15 is offline
post #26 of 40 Old 07-15-2018, 04:54 PM
Versa15's Avatar
Found this on eBay today. Several different sellers have them. But all from China with long ship times. I ordered one to see. If nothing else, I'll use the 8 pin connector shell and move the pins over from the 32 connector.
(EDIT 7-27-2018) Received the 8 pin connector with the phono plug lead in the mail today. I'll cut the phono plug cable off and solder the wires coming from the console AUX jack. I want it to look factory and also the phono plug it came with is the older big style that won't fit in most cell phone cases. It uses all 4 wires like original. Hey! I now have a nice shielded cable with correct conductors to run the mic wires from the A pillar to the head unit, lol. I need to find this cable in bulk incase I find a stock Versa Sedan rear camera.
ID:	14068   Click image for larger version
Versa15 is offline
post #27 of 40 Old 07-17-2018, 05:57 PM
Versa15's Avatar
I noticed last night while reviewing the wiring diagrams, the Display Audio and Nav units take there Ignition +12V from the ACC Relay 2.
Is that the one that retains power after the key is off but only until a door is opened or a given time expires?
Base and Mid Audio units shows switched +12V direct from ignition and not the the ACC Relay 2.
I prolly won't feel like running another wire and splicing into that ACC Relay output. But, I can get a little OCD on everything being or looking as if factory original.
Versa15 is offline
post #28 of 40 Old 07-17-2018, 11:17 PM
Versa15's Avatar
July 27, 2018:
I received a replacement Display Color Audio head unit today. The first one was DOA. The eBay seller had pics of it powered up on the auction page. But looks like it had taken a hit to the power/volume knob. The knob wobbled when I turned it and wouldn't turn on. They sent another one. I haven't tested it yet. The face looks ok, not perfect, but acceptable. It didn't come with the vin from whatever vehicle it came from. The first one was out of a 2016 Sentra. I'll try the first ones vin for the Nissan Connect.
Versa15 is offline
post #29 of 40 Old 07-18-2018, 10:32 PM
I need you to call me with the manual up and talk me through what you are looking for.
Anyhoo, I pulled the trigger and purchased the PAC Audio SWI-CP2 Steering wheel harness kit and PAC Audios BT-SWC-NI1. Ebay has a sale buy a 100 dollar ebay card for 90 bucks then use code PRIMO for 20% off purchases over 50 bucks. I paid 73 before codes and discounts for the adapter and black box. I purchased a car play radio for cheap at crutchfield, but held off installing it due to loosing steering wheel controls.
Also need to run power lead for amp and leads for rcas and adjustable cross over with level adjustment.
If this sounds good Ill go to a 3 thousand watt crescendo amp and 15 inch l7 kicker square sub in a full wave band pass box.
post #30 of 40 Old 07-19-2018, 08:46 PM
Versa15's Avatar
Also need to run power lead for amp and leads for rcas and adjustable cross over with level adjustment. [IMG class=inlineimg]/images/NissanVersaForums2/smilies/tango_face_devil.png[/IMG]
If this sounds good Ill go to a 3 thousand watt crescendo amp and 15 inch l7 kicker square sub in a full wave band pass box. [IMG class=inlineimg]/images/NissanVersaForums2/smilies/tango_face_surprise.png[/IMG]
At the moment, I'm not looking for diagrams but simply waiting for a new Display Color head unit. The seller is sending me another one. Hopefully it's in mint condition.
Versa15 is offline
audio , bluetooth , nissan , streaming , versa
