2016 Versa SV radio swap - BT buttons and mic don't work - Page 4 - Nissan Versa Forums
 5Likes
post #31 of 40 Old 07-19-2018, 09:09 PM
Versa15's Avatar
I received the replacement Display Audio headunit. I went junk yarding today and found a spare male white connector, 20 pin I think it is. Also couple odd connectors just for there pins with lead wires.
Maybe tonight I'll get the time to sit with my laptop, the Nissan repair cd and a note pad and plan out each wire pin position to be moved and or added. Lately it's been very comfortable outside until noon, then very hot after. Maybe I can get this done in the morning.
Versa15 is offline
post #32 of 40 Old 07-30-2018, 09:13 PM
Versa15's Avatar
The 20 pin Add a Subwoofer wiring harness arrived today along with a Nissan accessory satellite radio antenna. It's the one that mounts to the roof with 3M adhesive tape and the wire tucks under the glass rubber. Wish I had the actual Versa combination FM radio/Satellite radio antenna. But didn't find one on eBay.
I already have the 32 pin Axess add a camera harness and the 8 pin AUX connector. So hopefully the upgrade stereo swap will be done this week.
Versa15 is offline
post #33 of 40 Old 07-30-2018, 09:39 PM
Good to hear. I use to in the early days of my stereo mods adding extra bass was to buy a bazooka pass through connector harness. I then installed the powered sub behind the driver or passenger seat.
I showed the pac controller and bluetooth module delete connector to a radio installer. He never seen or heard of either before. He tells people if they love the cars bluetooth or steering wheel controls to keep the factory radio or loose them and use a voice activated head unit and have siri or google do all the work.
post #34 of 40 Old 08-01-2018, 06:29 AM
Versa15's Avatar
I didn't realize when I ordered the Add Subwoofer harness, that I didn't need it for the Mid Audio to Display Color Audio upgrade. There is no change in the 20 pin harness between the two. But I would like to add a sub in the near future.
I have added 3 more jumpers to the PAC BT-SWC-NI1. I noticed more wires in that harness to the External Bluetooth Module that will be unused by the Display Color Audio head unit. So why not create more jumpers to forward the MIC signals to the head unit. On the Axxess Add a Camera harness, I've moved the corresponding pins from the rear Bluetooth harness to the correct MIC Input pin positions on the head unit.
I have a Nissan accessory satellite radio antenna I found on eBay. Has the correct Pink connector for the Display Color head unit.
I separated the AUX input wires off the 32 pin Axxess wire harness and routed to the 8 pin connector. I have the pick tools to release the locking tabs on the pins and pull them out of the 32 and push them into the 8.
It's 1am and I'm stopping for the night. Will begin install into the car tomorrow. I still have the Reverse input to run to the head unit for camera. I also want to change the switched +12V from the ignition to the Accessory Relay-2, so the head unit stays on until the door is opened. Yeah, not necessary but I want too.
ID:	14102   Click image for larger version
ID:	14148   Click image for larger version
Versa15 is offline
post #35 of 40 Old 08-01-2018, 06:56 AM
Versa15's Avatar
I'm leaning toward a small under the front seat sub box. I just want more beat. Not so big on having sheet metal rattling vibration.
The PAC Bluetooth jumper should work fine. I'll find out tomorrow.
It simply bypasses the Bluetooth module and sends the Ladder Signals from the steering wheel TALK/HANG UP switch directly to the head unit harness.
When I plugged the Display Color Audio head unit unto the 2015 Versa Mid Level Audio head unit connectors, without making any changes first, the SOURCE, UP/DOWN, and VOLUME buttons worked. It was only the TALK/HANG UP switch that did not work.
Hopefully everything works out tomorrow and the install will be done.
They way I have planned it out, I can remove the adapter harness at the head unit connector. Remove the PAC jumper and reconnect the External Bluetooth. Then re install the Mid Level Audio head unit and all will be back to original for any warranty work. Particularly the out of stock Mid Level Audio head unit the dealer ordered 2 months ago. The screen is dead on this one. After they have not delivered on a second key fob key that was promised during the sale. And the sinking feeling that the lifetime power train was not in writing. I no longer trust the dealer. I think they tricked me into buying an extended bumper to bumper that the car came with anyway because it was a Certified Pre Owned. Have to check on that this week and demand a refund on it.
Versa15 is offline
post #36 of 40 Old 08-01-2018, 06:55 PM
Versa15's Avatar
TOTAL AWESOME SAUCE!!!!
Streaming Bluetooth audio works.
Microphone works.
All steering wheel buttons work.
Speakers still sound like shiitake mushrooms. Display Audio has better low frequency but only at lower volume. Turning it up past 22 and it still sounds like under driven speakers. Sub is next with filters on the door speakers.
I haven't ran the Reverse +input to the head unit yet.
Versa15 is offline
post #37 of 40 Old 08-02-2018, 12:58 AM
Versa15's Avatar
The RCA cable that I had run from the deck lid up to the passenger kick panel, has a power wire made into the cable. The camera end of it, I connected to the reverse light. So the dash end of that cable already had the reverse light feed for the head unit.
I'll have to put up with double guide lines until I can find a used Versa Sedan camera.
ID:	14110   Click image for larger version
Versa15 is offline
post #38 of 40 Old 08-02-2018, 07:23 PM
Versa15's Avatar
I don't suppose this Rouge subwoofer would fit into a Versa space saver spare tire? Lol
Versa15 is offline
post #39 of 40 Old 08-02-2018, 10:54 PM
You can easily out do the oem subs. I got a small kicker and will be going to a 15 inch kicker.
post #40 of 40 Old 08-04-2018, 06:18 AM
Versa15's Avatar
August 8, 2018
I tried to activate the Nissan Connect Apps on this unit. First tried the Vin provided by the salvage company I bought the Display Color Audio head unit from. The app said I wasn't the owner. I tried my Versa vin and it wouldn't say anything but just crash the app. Today I received the used 2015 Versa AM/FM/XM roof antenna I bought off eBay. Again, the salvage yard had the Vin printed on the pull ticket. I tried typing it into the app. It activated!
Facebook, google, iHeart radio, Pandora, twitter, and Trip Advisor are the only apps listed. I only choose iHeart and Pandora. So far I'm loving iHeart. I haven't listened to Z100 in years.
Versa15 is offline
audio , bluetooth , nissan , streaming , versa
