Adding power locks to base model - Page 3 - Nissan Versa Forums
post #21 of 45 Old 08-28-2012, 06:04 AM
fereo0's Avatar
Originally Posted by V_for_Versetta View Post
Can be done but the BCM needs to be programmed by Nissan. Also check my above posts in this thread they kinda cover the rest of your post
By the way on my model I don't know if its true for every model (09 nissan versa s manual everything 1.8) or year versa they were unable to reprogram the bcm because they said my bcm had no option to even turn on for power locks and windows
fereo0 is offline
post #22 of 45 Old 08-28-2012, 11:24 PM
MizuShinobi303's Avatar
What year was the donor car? I am interested in doing the same thing but mine is a 2011.
PS
sergmx - I don't know if you are still reading this but the OEM fog light switch is on the indicator stock as a middle dial. Many people have used that spot for aftermarket things like fog lights but the OEM is definitly on the indicator stock.
Nissan Versa HB 6MT 1.8L I4 Magnetic Grey
MizuShinobi303 is offline
post #23 of 45 Old 08-29-2012, 04:05 AM
fereo0's Avatar
I dont know I got them from some guy on craigslist.
fereo0 is offline
post #24 of 45 Old 08-30-2012, 04:49 PM
Good to know
post #25 of 45 Old 06-30-2013, 06:18 AM
Fereo0 - I also have a 09 s all manual. I had an 07 SL parts car and have everything from it. I have already swapped the doors and connected wiring. The passenger door had a second connector though that mine didn't have, so i need to dig for that harness i'm assuming it's taped up.
From what I can tell you are correct that the 09 S BCM (manual) does not have a power window option. When you swapped in the donor BCM did you then have to have your keys reprogrammed for the new BCM? The 07 Donor was an SL with Intelligent key and I've been afraid that I'll need to find another year model bcm without the intelligent key programming and then get new keys coded to the new BCM.
Could you please advise me of how you finished this part of your swap? Thank you!
westbound2010 is offline
post #26 of 45 Old 06-30-2013, 05:08 PM
fereo0's Avatar
The part that i needed to replace was all of the in dash wiring.
2009 Nissan Versa
1967 Ford Mustang Coupe 289
fereo0 is offline
post #27 of 45 Old 07-01-2013, 03:58 AM
fereo0 thanks your reply I actually have that if it's needed .. did you have to recode your keys to your replacement bcm though or was it plug and play?
post #28 of 45 Old 09-27-2013, 03:50 PM
TKO
Quoted: 15 Post(s)
I'm thinking of buying an aftermarket power locks and window kit and installing them in a Versa Note S Plus. However, I've been reading on the forums about having to install a new BCM as well if I want to put in power locks and window kits from the Nissan factory.
Do I need to install a new BCM or reprogram the existing one if I want to install aftermarket power locks and window kits?
TKO is offline
post #29 of 45 Old 01-29-2014, 11:30 AM
hey, I'm also new to v forum. I have a 2010 hatch 1.8 with 138,000 miles I bought it used at an auction, battery was dead, I bought a new one, but I also noticed the radio had power ever after the key was out of the ignition , next day, battery was dead again so I just disconnected the radio.I know for sure its not a radio problem, It's an active power wire that stays on after I turn off the car. Does anyone have a solution to this problem, most of my relays are cool to the touch.Since I am new to versa I jst dont know where my accessory relay is located and I dont have a manual. It's a base model with no power windows or lock and also has a flashing red car icon with a key symbol on instrument cluster, I also dont know what it means. Thanks for reading
persa versa is offline
post #30 of 45 Old 04-22-2014, 02:08 PM
'14 Versa S Viper Alarm and remote entry?
Hi,
Im new to the forum and i just bought a 2014 Versa S. I was wondering if i could hook up a viper alarm and get power locks with that, instead of going with the OEM fob. any suggestions?
dreis91 is offline
