Dome light don't turn on upon unlocking - Nissan Versa Forums
post #1 of 14 Old 10-10-2011, 05:44 AM Thread Starter
Hi Guys,
I need some help to solve an issue on my Nissan Versa 2008 Hatchback, my dome light stop turning on when i press the unlock button on the remote, but turn on when i open my door.
So far i remember, when you turn off the engine, the dome light also turn on but it does not anymore.
Do you know what may be the issue?
Thanks.
snnplswk is offline
post #2 of 14 Old 10-10-2011, 01:45 PM
iluvmyVersa08's Avatar
Did anyone change the setting on the dome light? (The little tab beside the light).
iluvmyVersa08 is offline
post #3 of 14 Old 10-10-2011, 08:41 PM
Touch's Avatar
did u put led bulbs ?
Touch is offline
post #4 of 14 Old 10-10-2011, 10:55 PM
bboy_romeo's Avatar
I have LED's in my v and they don't cause the issue snnplswk is having, so maybe its something else?
- 6000k Bi-Xenon HID's, Custom Catback w/ Magnaflow muffler, AEM CAI, Tanabe SUSTEC NF210 Lowering Springs, Tanabe Strut Tower Brace, Ultra Racing Rear Shock Tower Brace, 17" Konig x906 Black Wheels w/ Falken tires 205/45/17, JVC KD-R208 deck w/ Kenwood amp and 10" Energy Sub, blue interior painted, 3 piece mesh grille, debaged, tinted tails, versa 3rd brake light decal, vortex roof spikes, window visors etc..
bboy_romeo is offline
post #5 of 14 Old 10-11-2011, 08:32 PM Thread Starter
Thanks for your reply guys.
Yes i switched to led lights (trunk, dome, map), and the switch is on "Door" position, so far i remember the yellow bulb was having the same issue (before i switch to led). But this is something heppening recently
snnplswk is offline
post #6 of 14 Old 10-11-2011, 08:43 PM
RedAlertV's Avatar
Quoted: 68 Post(s)
Did you by any chance disconnect the battery for any reason? I had a similar issue when I installed my CAI where I had to remove the battery for better access. Once I hooked it back up my headlights & Taillights wouldn't flash as they usually do when you unlock and lock the doors. To this day they still only flash when i lock the car and not when unlocked, never had the dome light issue though.
11' 1.8 6sp HB
RedAlertV is offline
post #7 of 14 Old 10-14-2011, 07:58 PM Thread Starter
Probably . . . I don't remember. well it seems i'm stuck
snnplswk is offline
post #8 of 14 Old 10-24-2011, 04:51 AM
4DRZ's Avatar
Just so all knows, if you dont already, the Versa, like many other Nissans use a - door wire that goes + when the door is closed. For dome light operation a grn must be made in order to allow for the dome light operation. Without it just the on/off part of the dome light will work. My wife's Versa is a 2010 HB and I have recently added all LED interior replacement bulbs, as well as front/rear led footwell lights/rear LED lights under driver/passenger seats that were tied into the domelight. No issues. I played around with the circuit and verified that without a dedicated - continuity, only the basic/on/off woul work. Hope this helps...you should take a multi meter and verify the 3 wires either under the passenger side visor, at the dome light, or the passenger side A-pillar. the color codes are blk/yellow/brown.
1. Blk= 12V-
2. Yellow= 12V+
3. Brown= 12-
with door open, and 12V+ with door closed. Each door of the Versa uses a different color wire unique to that door which is also the same wire function as the brown wire that is mentioned above. Later this month or so, I will be installing the overhead map light/sunglass holder in my wife's car that I found online from an SL model. i will then be installing a 30/40amp relay on the dome light circuit to support the addition as well as to allow "other" lighting possibilities.
4DRZ is offline
post #9 of 14 Old 10-24-2011, 01:20 PM
JoshG's Avatar
Quoted: 90 Post(s)
^^^ I don't really use my dome light so I doubt I'd upgrade to LEDs but thats great info. Adding a map light/sunglass holder would be good though.
2010 NISSAN VERSA 1.6
1991 MAZDA B2600i
JoshG is offline
post #10 of 14 Old 10-24-2011, 04:26 PM
Well this maybe a long shot, but I had a problem with my 09 where the doors wouldn't unlock when taking the key out, and they wouldn't lock after I hit the certain speed. Well when I took it in to have them look at it, they said the dome light was supposed to turn on and off by the keyless remote like you stated as well. Come to figure out, My BCM (body control module) had went bad, and that was the cause of it. They replaced my BCM and everything worked great again. Have your BCM diagnosed, that's a start.
Versa S 2009 is offline
dpme light
