I have a 2015 s plus sedan. Has the boring basic cluster the base models have. Bought a used note with the 3 rings cluster (not the kind the sedan SV has). Its for 2015 to 2018 wiring harness. I plug it up and upon immediate plug in a fuse blown. When I plugged it nothing worked. No lights or digital mileage or even gas hand gauge worked. The rpm did have a rev and I rolled to see if the speedo would come move. So outside of rpm and speedo working nothing else does. Does anyone have a pinout or does the actual sv sedan cluster from the same year like my S plus plug in play? I do know the notes are different than sedans not sure how much different wire wise. Any help is appreciated if anyone has tried. Below is the cluster I'm trying to install.
The Note is wired differently from the sedan.
You will have to do some very extensive wiring to get a Note cluster to work in a sedan... and it still may not work.
Well put old cluster back in now I got no turn signals no illumination lights when dark and a check engine light on. Checked all fuses none look blown or split. I'm stumped. Turn signals work outside of car just not on my cluster.
Would another cluster of the same cluster fix the problem? It still drives and runs fine just no light on the display or turn signals. Everything else works.
Related Threads
115.5K posts
20.1K members
Since 2008
