-   Lounge Area (https://www.nissanversaforums.com/lounge-area/)
-   -   New Tires 😬 (https://www.nissanversaforums.com/lounge-area/42050-new-tires-x1f62c%3B.html)
whicky1978 06-30-2018 06:41 PM
14 Attachment(s)
I got these Pirelli tires at Sam’s Club for $276 with install on my Nissan Versa 2014
Pirelli P4 Four Season Plus - P195/65R15 91T Tire http://www.samsclub.com/sams/a/prod15120205.ip
Note they are one size larger oversized and the tread 😁 is way more than the Goodyear Fuelmax. they did not have these tires in the factory size so I went bigger to get the deal.
whicky1978 06-30-2018 07:24 PM
11 Attachment(s)
These oversized tires will have more rolling resistance correct? I’m Ok with that.
Alan_nc 06-30-2018 07:59 PM
You are correct. Might cost you an almost unnoticeable dip in gas mileage. These are softer rubber tires and will probably wear somewhat faster than your previous ones.....but should hold the road better and be more fun in hard corners.
Cobb 06-30-2018 09:35 PM
I too plan on going up a size when I replace them on my car. Ive done that on all my vehicles and it makes the handling better with little to no effect in mpg.
whicky1978 06-30-2018 11:35 PM
It will help me not peel out as much on my 5 speed when I’m up a steep hill.
whicky1978 07-01-2018 02:38 AM
11 Attachment(s)
I will manually track my gas mileage and report back. The size of the tire may throw off the calculations the computer makes in the car and not show the true gas mileage change.
whicky1978 07-05-2018 03:28 AM
My speedometer is accurate now 🤨
whicky1978 07-18-2018 03:54 PM
Getting 33 mpg which is on the low end of normal.
Cobb 07-18-2018 09:54 PM
What psi are you using? Tire or door jam psi? Have you traveled a thousand miles on them yet? Its my xperience it takes a thousand to break them in. You said your speed is now accurate. Are you calculating the mpg off the tire size or the dash readout?
whicky1978 07-22-2018 10:03 PM
40 psi this last trip. I’m calculating mpg manually miles per tank divided by the number of gallons of gas to refill. I did not account for the tire size.
