Glowing catalytic converter - Nissan Versa Forums
post #1 of 3 Old 03-06-2019, 02:19 AM Thread Starter
Thought I had a catalytic converter problem, changed it. Getting po300 miss fire code, changed plugs. Car is hard to start . Any ideas which direction to go?
Billy g is offline
post #2 of 3 Old 03-06-2019, 01:23 PM
First Steps I would test are.
1) check the air pressure coming out of the tail pipe, does it feel normal? You are checking for a clogged catalytic converter or other exhaust component.
Sorry, I know this test is very subjective.
2) What do your fuel trims look like, short term / long term.
It's my understanding that a glowing cat is usually a result of a clogged exhaust, or raw fuel being burned by it.
Seeing how you are having miss-fire's I assume it's the raw fuel issue.
However, If I had to make a guess off the top of my head without any other facts,
I would say a bad fuel pressure regulator or vacuum leak
scarecrowdjinn is offline
post #3 of 3 Old 03-06-2019, 11:41 PM
Quoted: 94 Post(s)
May be ruining second cat now, they can go bad quick. The mechanism is this: the raw fuel not burned due to misfire then burns in the cat and in short order melts the matrix inside when the temperature goes out of sight, cat is then clogged.
Misfire codes are commonly ignition issues first but can be vacuum leak. Maybe a seriously leaking injector.
Similar Threads
2011 Versa catalytic converter question drummer General Versa Discussion 0 03-16-2017 11:05 PM
Catalytic Converter Assistance Anthony Costabile Engine Forum 1 02-06-2017 06:45 PM
Replacing Catalytic Converter VersaBaby General Technical & Electrical 3 06-09-2016 12:26 AM
Catalytic Converter Replacement Help 209primer Engine Forum 2 03-23-2015 02:14 PM
Worth replacing the catalytic converter? chemzly Engine Forum 10 03-20-2015 07:57 PM
