-   Other Automotive Discussion (https://www.nissanversaforums.com/other-automotive-discussion/)
-   -   What to do if i want to weld (https://www.nissanversaforums.com/other-automotive-discussion/35113-what-do-if-i-want-weld.html)
VersaQuebec 02-05-2017 02:49 PM
I need to know if i want to weld muffler what to do ...
Remove negative pole ???
DD
Cobb 02-05-2017 10:34 PM
Negative poles??? :surprise
You can clamp or weld exhaust. What are you doing to give us a better idea?
You can weld by brazing with a gas torch or arc weld with an electric torch or even a car battery, jumper cables and a welding rod.
Im more of a clamp guy when it comes to exhaust. :nerd:
amc49 02-06-2017 05:20 AM
VersaQuebec 02-06-2017 08:23 PM
If you use TIG so you have to remove negatif pole or use a zap ... what are you doing when you weld on tig ...
DD
Clevor 08-02-2017 11:10 PM
I had a 1986 Ford Mustang with 5.0 liter V-8, which I bought in 1993 for $2000. What a rustbucket! It was a big project, only reason I bought it was the mag wheels and tires on it was probably worth what I paid for it. A/C was dead, stereo removed, dash all cracked, rusted out rear hatch. Found out the overdrive band in the AOD was on it's last legs as would hear a scraping sound when it engaged. Bought it from a guy name Marquis DeSade so what do you expect? Funny thing is the engine, with 110,000 miles did not eat a drop of oil.
I did a lot of rust repair on the car where I cut out and replaced the rust with new sheetmetal using a fluxcore MIG welder. Back then, I always disconnected the battery when welding on it. However I forgot to do this on several occasions, and nothing happened. I did about $25K worth of autobody work on that car, if you had a pro do it.
The new cars these days do all kinds of funny things when you disconnect battery power so sorry, your guess is as good as mine. You may want to ask around at your local autobody shops.
More than likely you won't be TIG welding on the car as it's used for finesse work. Most work done on mufflers is arc but MIG gives much better welds.
Chad 08-02-2017 11:52 PM
DD
I use flux core in a cheap A/C welder and disconnect both terminals, never fried anything.
VersaQuebec 08-06-2017 07:59 PM
Hi ... when you mentionned that you disconnect both pole, does it effect on computer if it is not connected?
DD
Alan_nc 08-06-2017 09:27 PM
As far as the computer is concerned disconnecting two poles is the same as disconnecting one. You have stopped the flow of current/electricity throughout the car with either.
