1 - 10 of 10 Posts
I saw this really cheap 2010 6 disc radio from a cube on ebay. It was brand new, and the owner had a dvd screen put in his car. They wanted only $65 for it!!! CHEAP!!! I know what a good deal!!! Well I called the dealer, and they said that the 2010 cube 6 disc radio isnt compatible with the 2007-2009 nissan versa S, SUCKS!!! He said that it could be done, but it would void the warrenty!!! another SUCKS!!!! so I just have to weep and understand that there goes a really, really, really good deal... So that SUCKS again, and if anybodys woundering about this, well,....now you know!!! It still SUCKS!! lol
I do not believe this for a second. First off you can't void any warranty by putting in another radio. How is that possible?
I had a 99 infiniti g20 and I put in a 2005 pathfinder radio. Guess what? It plugged right in and worked perfectly. I can not say for sure the cube radio will work but I'm betting it does and I would not take what they told you as fact. I am betting if the plugs are the same then radio will work. Unless the cube radio has an external amplifier. Then that is a different ball game.
Other thing is the mounting points may not be the same. I had to make custom brackets for the pathfinder radio but it wasn't hard.
well, The heres the thing. Versa and cube share the same things!?!?! Like radios, tires, engines, trannys, wheel covers, speakers, etc. When did it change? It looks like the same radio that is in the 2010 versa. He said that there may be a wire difference, but he said he dosent know exactly why it wouldnt fit?!?! huh??? the numbers dont match what the computer is telling him. and because they arent the same numbers, even though its a nissan part, its not for the versa,..... so I would void the warrenty. Because they would have to FORCE the radio into fitting. I only assume its wires..... BUT HOW COME YOU CAN INSTALL AFTERMARKET HEADUNITS?!?!?! hmmmmmm? Im glad im not the only one who thinks this is bull crap. They look like they same exact radio?? cube and versa share everything together!!!
Discussion Starter #4
and how come the 1.6 versa can have the 6 disc or 1 disc cd player?? Unless 09 versa is compatible with 09 6 disc. This is a 2010 6 disc
ok... this is starting to confuse me. Im starting to think nissan changes the numbers every year. Ok. I looked at my radio and its numbers are 28185-EM32A. He told me the only one compatible is 85185-PN2812L. HUH????? What you told me and whats in my car are two different numbers?? Does numbers really matter? Please.... does someone know about this stuff and these stupid numbers? Cause Im all out in confused land. Thanks.......
that cube radio is a good price. Buy it and try it. If it doesn't work I bet you sell it for more then you paid. If I had the $$ I would have bought it already.
Discussion Starter #9
do u have a radio at all cuz i have one in the room not being used and its not 6 disk but its a cd player and dont have the anx plug in
yeah I have one. its the factory 1 disc radio from the S model. But this was a really good deal on a nissan cube 6 disc. so im woundering.....
Discussion Starter #10
Well I was out bidded and someone else got it, o well. Now I know and wont hesitate next ime, lol
1 - 10 of 10 Posts
