Hey guys I’m wondering if you have had any problems with your versa fogging up really really bad in the winter and how you fixed it? I’ve heard the sunroof can cause problems but I don’t have one and my ac is always turned on. any suggestion?
Yes and no. Yes because using outside air makes the inside air not as cool, a loss in a/c there. No, because outside air brings in more moisture and that is what causes the fogging to begin with. Recycle removes more and more water from inside the car if you don't bring in more to simply stymie that.
The fix is heat, which raises the internal cockpit temperature to not fog up. Or turn the a/c off, what nitwit uses it all year long???
Keep temp at full hot.
Never set fan below 2.
Never recirculate in winter.
If you get too warm, crack a window for a few minutes.
I drive for a living and I NEVER have a problem with windows fogging in winter by doing this.
I agree, A/C on in the winter, fresh air mode only.
double check your drains on your A/C and windshield cowl, maybe those are letting a little water into your car.
