1 - 8 of 8 Posts
When i push the o/d button on my gear shifter nothing happens. 08 versa 1.8 s cvt transmission
When you press the OD button and you see it light up on the dash what happens is that it locks the tranny in a lower gear; short of like downshifting with a manual. However keeping it there actually lowers gas mileage, and yes it stands for overdrive...
Just because the mode switch for OD is on does not mean you are in OD, which is a non-literal term anyway on a CVT. The highest value there may be with it off, to use more engine braking like in the mountains. Other than that leave it on and alone, as you won't hear anything anyway, the CVT does all that smoothly with zero 'gear changes'.
I have a 2012 Nissan Versa Hatchback 1.8L S trim automatic. I'm having the same problem. However, when I press the Overdrive button, my OD light on the dash doesn't even come on.
1 - 8 of 8 Posts
