1 - 13 of 13 Posts
Discussion Starter · #2 ·
Also looking to add some power windows/locks (I think the person who helped me install my sounds stole my actuators for power locks when I wasn't looking on all 4 doors). Any info on cheap kits or should I just hitup junkyards hoping they got some versas
As far as I know they're only prewired for fogs if they have the power package(power windows, locks, etc.). Mine doesnt so I had to wire my fogs. Not hard, just takes time, and patience. :thumbsup:
Would it be simple plug and play? Also I swore I've seen someone sawing out the covers that the factory placed over housing unit.
It's pretty simple. The kit has instructions so it's not hard. And yes, you can cut your factory covers, I had to that as well. Just need a dremel if you want a clean look. My fogs were $20 at Wal-Mart. :D
How's the twenty dollar lights holding up?
tyvm sir. I want them HID so the $20 are perfect. the roads in hawaii are f*#@ed... needa see them potholes
No problem. If your V has the power package and you plan on getting Wal-Mart fogs you have to use aftermarket wiring, unless you want to break into the factory wiring. In that case you need a factory switch, and a relay. I would use aftermarket wiring and switch.
That's not bad. You just have to wire them yourself like I did. Mine have been great! I've only had one issue and that was because I used a different switch.
1 - 13 of 13 Posts
