2007 Misfire Diagnosis? 148K miles...
413 Views 8 Replies 6 Participants Last post by  Chad007
I'm at a loss with this one - maybe someone with more experience than I can help!
I have a 2007 hatchback with 148K miles that is throwing a P0302 (Cylinder 2 Misfire). It is very noticable when driving, much worse once warmed up and almost stalls at idle.
Here's what I've done so far:
Checked Compression (within range, Cylinders 1, 3,4 = 14 Bar, Cylinder 2 = 13 Bar)
Replaced all plugs (OEM)
Replaced all coils (OEM)
Checked PCV Valve (shake test, suction test)
---absolutely no change in symptoms---
Drained all fuel from tank & flushed lines + cleaned injectors (using OTC tooling/cleaner with specified pressure @ 51 PSI)
Replaced all fuel injectors (non-OEM)
---substantial improvement, now driveable, less hard miss, soft misses frequently, feels like stalling at idle w/ A/C running
Mechanic friend swears that this is because I'm using aftermarket injectors, but wouldn't that cause other cylinder misfires, too? What are the odds that only cylinder 2 would do this before and after? Related to the 1 Bar difference in compression?
I have not yet checked the fuel pressure (don't have the tooling). Is this route worth going down?
Other ideas?
Thanks for any help in advance!
Chad
1 - 9 of 9 Posts
Suggest you check fuel pressure at the rail. My '07 had a failing fuel pump that resulted in uneven fuel delivery to the cylinders with drivability problems. Replacing the fuel pump made all the difference.
  • Like
Reactions: 2
Awesome, thanks for the response! I'll give it a shot and report back!
don't forget to report back!! :D
Suggest another compression test using a different gauge. Those numbers looked artificially high.
Check intake manifold for any vacuum takeoffs on that one cylinder runner and if they might be leaking. Misfire is commonly ignition but can be from lean too.
Any other codes?
Worn valvetrain like a single dead lobe on cam can do it.
Estoy perdido con este, ¡tal vez alguien con más experiencia que yo pueda ayudar!
Tengo un hatchback 2007 con 148K millas que arroja un P0302 (Cylinder 2 Misfire). Se nota mucho en marcha, mucho peor una vez calentado y casi se para al ralentí.
Esto es lo que he hecho hasta ahora:
Compresión Comprobada (dentro del rango, Cilindros 1, 3,4 = 14 Bar, Cilindro 2 = 13 Bar)
Reemplazo de todos los enchufes (OEM)
Todas las bobinas reemplazadas (OEM)
Válvula PCV comprobada (prueba de depresión, prueba de succión)
---absolutamente ningún cambio en los síntomas---
Drenó todo el combustible del tanque y enjuagó las líneas + limpió los inyectores (usando herramientas/limpiador OTC con la presión especificada a 51 PSI)
Se reemplazan todos los inyectores de combustible (no OEM)
---mejora sustancial, ahora manejable, fallas menos fuertes, fallas suaves con frecuencia, se siente como detenerse en ralentí con aire acondicionado funcionando
Un amigo mecánico jura que esto se debe a que estoy usando inyectores del mercado de accesorios, pero ¿eso no causaría fallas de encendido en otros cilindros también? ¿Cuáles son las probabilidades de que solo el cilindro 2 haga esto antes y después? ¿Relacionado con la diferencia de 1 barra en la compresión?
Todavía no he comprobado la presión de combustible (no tengo las herramientas). ¿Merece la pena bajar por esta ruta?
¿Otras ideas?
¡Gracias por cualquier ayuda de antemano!
Chad
[/CITA]
Chad
[/CITA]
Buenas noches, entre a este foro y leí tu problema con un versa 2007. Tengo un versa 2016, desde nuevo lo uso como taxi de app, ya tiene 280 000 kms. Hace unos meses, se encendió la luz del check en forma intermitente, sobre todo cuando calentaba bien, lo lleve con varios mecanicos, codigo P0301, comencé por la bobina (por decisión del mecanico, puse genérica, para probar, fall, me dijo hay que comprar originales las 4, fallo, bujías, fallo, repuesto de bomba, fallo, sensor de cigüeñal, lavado y programación de cuerpo de aceleración, nada, decepcionado así me lo llevé, me di a la tarea de aprender el método de sacar el código y borrarlo manualmente a falla de un scaner, change luces de freno, pues una que este en corto o fundida también genera falta de aceleración, aunque eso no genera luz de check, un día después de dejar un servicio, me lo lleve a casa en 3 cilindros, llegando como otras veces abrí el cofre, esperando tocar algún componente qué aliviará la tembladera, por inercia toque hacia abajo la mangyera pequeña de la valvula pcv, como por arte de magia se esrabolizo, por fin, lo había encontrado, cambie la manguera, despues me sucedió con el P0302 y era la otra manguera de respiración de vacío de la PCV, hojala mi testimonio sirviera de algo, saludos y muchas gracias.
I just went through this with my 2008 Versa. Send it to the dealer and spent $700. I still had a miss on cylinder two when I left there. I fixed the problem myself yesterday. I took it all apart yesterday a little bit of oil was getting past my valve cover into my spark plugs. So I resealed it. I replaced the coils with OEM and Ruthenium spark plugs. When I took it apart I figured out real quick what was happening. The tech pinched the gasket on the intake manifold. I resealed and replaced the gasket. It's been perfect ever since. No miss at all.
  • Like
Reactions: 1
Fuel pump didn't work. I'll try William's suggestion. Thanks everyone!
  • Like
Reactions: 1
Any other codes?
I think you're on to something here with the vacuum leaks. Thanks for the suggestion.
1 - 9 of 9 Posts
