Hi all
Just installed the Takeda SRI in my Versa.. sounds good!
BUT = when I was taking out the stock airbox, I noticed that one of the cables coming out from the engine below the airbox was not connected to anything? It seems it was like this stock, There are cable ties which tie parts of this cable to the stock airbox. It seems very unusual
See pictures here -
P.S. Do I need to tie down the MAF sensor so the cable doesn't dangle? In the stock intake it was tied down, but with the Takeda I'm not sure where to tie it down.
That is just a breather tube for the transmission it is not suppose to be connected to anything. You don't have to tie up the maf wire though if you can zip tie it to something to keep things neat and tidy you should.
I've left my MAF senor cable dangle and so far it has yet to pop out. If I recall correctly there should be a screw that secures the MAF to the SRI and that screw has held tight even that one time all 4 wheels were off the ground and slammed hard on the landing.
