My daughter hit her passenger side mirror. Small damage to assembly but mirror glass missing. See replacement part online is it easy to put on?
Thanks for any help.
Usually the replacements come with either a pull-off piece of plastic (with adhesive underneath) or a small tube of glue included. Just try to get it aligned before you put it in place because you probably can't move it once it makes contact.
It really isn't that hard and will save you $10 to $30 if you do it your self.
Depends on the mirror design. Say on Fords the mirrors simply pop right off the adjusting studs and the entire glass including backing plate pops right in place of the broken one. I got mine at junkyards for maybe $5. Installed in seconds.
