1 - 1 of 1 Posts
I'm in the process of installing my Scosche FM Modulator. I'd be "done" by now but then I realized I needed two antenna adapters (the normal Antenna Adapter and the reverse antenna adapter) so the modulator can tap into the antenna and back into the head unit. So while I'm waiting for that to be shipped I had another question.
The FM modulator works via a switch that's supposed to mount somewhere unobtrusively on the dash, but I can't find a place to route the cables (two RCA cables and the power cable) from the inside to the outside... I'd love to be able to mount the switch under the dash.
Any suggestions on how I can run these cables out, preferrably without cutting/drilling anywhere? If I had to do that I'd just cut a hole in the back of the CD cubby, but I'd rather not do that.
1 - 1 of 1 Posts
