Typically manual transmissions do not come with dipsticks, not sure about Nissans though but if so, that would be a first (at least AFAIK).Thank you sir. Mine is a manual transmission sedan.
that.Typically manual transmissions do not come with dipsticks
The historical/usual way of checking M/T oil level is unscrewing the fill access bolt. The oil level should be just be in line with the bottom of that fill hole.
and that.Tranny fluid=oil.
