My 2008 Versa has a problem with the switch/cable under the shifter console. If you don't push the shifter lever extra hard against the stop when going into Park, the ignition switch won't go all the way to the Off position and thus the key won't come out.
Is there a common quick fix for this? What is the best procedure to get the console cover off of there? :thumbsup:
Give these two a look and see if it helps:
As I posted on another website, I myself tend to mod that setup to no longer work any longer, not needed if there are no children to put the cars in gear. It's a safety issue for that.
