My radiator just started to leak tonight when I was stuck in a long drive-thru line. I only lost about 20 oz of fluid so I am grateful for that. When I looked online for a replacement radiator, I noticed two types listed. Anyone know How I can tell which one I should buy? They are fairly inexpensive..
Thanks - this is my first post
I have a 2011 Hatchback 1.8S. Just for grins I went to RockAuto to view my radiator choices. Seems the differences pertain to whether you have an auto trans or CVT. Is this what you're seeing?
Sent from my SM-N960U1 using Tapatalk
if you go to nissanpartsdeal and input your VIN number it will tell you what part exactly your car has.
Transmission type nearly always determines which radiator you need for any car. You can use one equipped for an automatic transmission on a manual transmission auto but not vice versa. If you know which transmission you have CVT, automatic, or manual you can determine which radiator to order/buy.
Thanks everyone! I went to the above website and it says I have the automatic transmission. This makes sense in that I found a post here last night that you cannot feel the CVT shift as you accelerate and I definitely feel/see the transmission shift as I go. I am going to go to Rockauto above to purchase it - it is a sixth of the cost from Nissan.
Of course the leak is where the plastic and metal meet. I am just going to go ahead and replace the radiator hoses and thermostat while I have it apart too. It doesn't look too bad - if anyone has hints please let me know.
Thanks!
Discussion Starter · #7 ·
Just found another method - the shift positions. For an Automatic Transmission they are: PRND21. For a CVT they are: PRNDL. Sorry for my ignorance, b
You can tell whether you have an automatic or CVT by looking at the shifter. CVT has PRNDL standard automatic has PRND21.
Thanks for the response!
ut I appreciate the help.
