2009 Horn not working
18652 Views 4 Replies 3 Participants Last post by  VersaS09
2009 Horn not working - Fixed
2009 Versa S.
my daughter called and said her horn stopped working when she locks the car and does not work if she pushes on the horn from steering wheel.
I checked the 10A fuse and it's good.
I replaced the Relay so it should be good
When I push the lock button from the remote I can hear the relay clicking, is that good?
what else could it be. As far as I can tell all other electronics work on the car.
thanks
Dan
Maybe the horn itself has failed? Not sure if the horn is easily accessible but if so, check if power is getting to the horn using a test light or VOM.
Try this: on the key fob, press the lock and unlock buttons together until the car turn signals turn on.
Basically you can program nissans to have the horn come on or not when you press the key fob.
Red, I don't think this is just a key fob issue. The horn does not work even when the horn button is pushed on the steering wheel.
Thanks for the replies. I found the issue. one of the wires at the horn was not attached well. To be honest it was just a stripped wire that had black tape on it from the previous owner. I went to parts store and picked up some connectors, added that and she now has a working horn.
