Well it only too 7 years but I made it! I know we have a "how many miles" thread. Figured this is a way to see the high milers grouped together.
Discussion Starter #2
guess I am the only one :(
What repairs have been needed along the way and at what mileages?
What trans?
The only thing that broke on the car was the exhaust rotted off. I did not repair it. It's a little louder than it should be but not enough for me to spend money on it. Because of the exhaust I have a check engine light on for the O2 sensor.
I have done the front rotors and pads once at about 150k miles. I have added some r134-A a couple of times for the AC. But that issue seemed to resolve itself because it's been over a year since I had to do that. I've topped off the coolant a couple of times. Not sure where went. I was riding without a cap on the overflow for a while so maybe evaporation. I have no clue. I also have gotten new tires twice. Well first time at over 100k I replaced the stock tires with some used ones. Then after that I finally bought a brand new set.
I do see some wetness between the bellhousing and the engine. This may be a slight leak in the slave cylinder but I'm not sure. The clutch is working great so I am not concerned. So obviously the transmission is a 5 speed manual to answer your question.
The car now at 202k miles does need some work. It needs a new belt and the front brakes are making noise. The rears should be checked at this point too.
That's good information. Thanks, Rob. Also, consistent with what we've seen, especially exhaust-wise.
Rear driver's side brakes developed noise around 60k; shoes and cylinder were fine, but dust was excessive; thorough cleaning immediately eliminated. Subsequently, learned Nissan changed brake parts.
My 07 is at about 190k miles. I got it at 70k and the motor lasted another 100k hard miles which included several years of Autocross and a season of track events.
