I tend to try the least expensive solutions before firing the "parts cannon" at a vehicle. I would probably clean the mass air flow sensor (with the proper cleaner) and try some good fuel injector cleaner in the tank.
After that I might check for vacuum leaks (using propane). If you are not comfortable using propane or brake cleaner to check for vacuum leaks, don't do it. Personally, I have a hard time finding vacuum leaks by sight or hearing and utilize propane.
just my two cents...
