I just installed a new clock spring to clear a flashing airbag light. When I hooked up the battery the horn is on and won't stop. Can someone describe the horn contact circuit so I can try and fix this?
is the clockspring OEM? I would suggest buying an OEM new item for this part.....cheap replacements usually give issue after a while.
I found out many that gave issues while driving...one was the horn, it went off when turning the steering wheel.
Another issue might be the airbag copper band that makes contact.
