My First day on the Forum.
I am considering putting my 2014 motor, 1.8 into my 2011 versa which had a 1.6 motor in it. The 1.6 is not running well and I was gifted a motor from a 2014 which had a 1.8 in it. Wondering whether it will fit and will I have any issues with the swap!
Any advice would be greatly appreciated.
Should be a fairly simple swap. As with any engine swap make sure you use the computer from the "new" engine.
You don't mention transmission but it would sure be easier if you moved both.
Just to add to the above, are the exhaust systems the same?
I also wonder if the body control module will jive with the "new" engine and transmission.
X2, the engines are close but somebody will find I think more slight differences in there than they think..........
