Nissan recommends at 30k to replace the engine oil and filter, replace brake fluid (although this is recommended every 15k miles) also the engine air filter and cabin filter if applicable.
Everything else is mostly inspection of the car although if you baby your car you should be fine.
My sedan is approaching 15k and Nissan recommends the brake fluid be replaced but I will see what the dealer recommends, visually my brake fluid looks fine since my last oil change.
I would stick with OEM brakes, you can never go wrong with OEM equipment. The cheap stuff wears out to fast and makes to much noise. If your going to replace your brakes you might as well change the fluid to save time and money.
