NEED A TECH
See my second post in this thread thanks.
Question 2012 versa need help
hello im a newbee .glad i found this site mabe i can get some help.
my 2012 1.6 versa started to over heat in traffic and the ac quits working the fan does not come on i changed the fan relay and thermostat and it did not help. sitting in drive way ac will short cycle and blow hot and car will eventually turn on the temp light in dash ,get in and drive and in a few minutes it will start blowing cold again just like new.
i read somewhere on line that when you turn the key on the temp light will come on then turn off and this means the sensor is good .im not so sure.
i can take the fan relay out and put a jumper wire in and the fan will run and the ac seems to work fine sitting in the drive way.
i guess my question is what else makes the fan turn on and cycle properly besides the coolant switch.
my guess is the coolant switch is bad but there are no codes now or ever came on.
any help or suggestion will be greatly appreciate trying to get it done myself to save a buck .
