2012 Versa S right front door replace
Firstly, it is the right FRONT door, not the rear. Sorry.
My Granddaughter has crunched the right front door on her 2012 Versa S.
It will probably be less expensive, and a lot easier, to just get a used door, paint to match, and swap it.
How do I get the interior door panel off? The replacement door may not have a matching interior panel, so I'm hoping to get some guidance from the Gurus here on pulling the old panel off the crunched door and installing it on the replacement door.
The pics show the car before the damage, and a close up of the damaged door. If the rear door is opened, it scrapes the front door.
The exterior color is blue onyx, the interior is charcoal.
Thanks much.
Discussion Starter #2
All I need is a hint on how to pull off the interior door panel of the right front door of a 2012 Versa S.
Thanks much.
Sorry to hear about the door problems. Also, don't forget to use the search feature on the top right of the webpage! :wink
Here you go, good luck!
http://www.nissanversaforums.com/how-tos/1001-how-take-your-door-panels-off.html
2 Participants
sergmx
