21 - 28 of 28 Posts
I have found and fixed the issue, If anyone wanted to know what it was, the hvac control in the car is run by a hard wired when you turn the knob to hot or cold, the hot wire was slipping while trying to open the blend door, therefore no heat was coming through, while the cold knobs wire was still ok which explained why the ac was working well and there was no heat, also the air filter was smashed, whoever did the installation, did it wrong. It made the vent door stuck as well. Thanks for everyone’s input !
Glad it worked for you, and thanks for the feedback.
I have the same issue, how did you fix it? did you just replace the hvac climate control?
Thanks,
Anthony
Discussion Starter · #25 ·
You're welcome.
Congrats on the Fix!
And thanks for the updates
You're welcome.
Thanks for posting an update as to what the problem was. This may help someone else later on that's having the same problem. Too many times people go to forums to ask for help then never update with the solution to the problem so no one else benefits from the discussion later.
Yes, I totally understand how frustrating that could be, that's why I try to reply back.
Thanks,
Anthony
No, There is a wire on the hot side that is clamped on by a connector which opens the blend door, the connector was loose, so my friend (which happens to be a mechanic) said when i was turning the hot knob, the hot knob line was slipping from the connector which in return did not open the blend door, which caused no heat. all he did was moved the line back to the connector and clipped it down hard with a small clamp, so when i turn the hot knob now it catches with the connector and pulls the door open again. It was insane, the heat was SO HOT after it opened.
You're welcome.
You're welcome.
Hi! I have a 2012 Versa with no heat and hoping this is the fix! Could you expand on how you accessed the hot knob line that was slipping? Was done by the blend door or behind the hot/cold knob? Thanks!
Personally, I accessed the hard wire from behind the knob tracked it down took, it off the clamp and pulled on it!
21 - 28 of 28 Posts
