My passenger side kept flooding from all the rain the past week. A friend said the issue is likely that the Cowl isn't draining and is flooding into the cabin air filter down into the passenger side. After one night of excessive rain, the water was so bad there was inches of standing water all the way into the back of the car. I vacuumed out the water as best I could. Shortly after while driving, ABS/traction control lights on dashboard came on, then driver side door light on dash came on, it kept going off/on and spazzing out. This morning my car won't start. No power at all, no sounds when trying to turn. Couldn't even get my doors unlocked with my remote unlock. A friend said its likely some wiring was being shorted overnight and caused the power to drain. He is coming over to help work on the cowl issue(thinks a clog is causing the flood) but likely won't be able to fix the electrical problem.
Any ideas or advice? Obviously will have to take it to a mechanic.
No comprehensive insurance? That would cover the repair less your deductible, if not total it out completely.
Not sure if it would be a mechanical failure that caused the flooding any more than if he left the windows down by mistake. I've read where insurance paid for an engine when someone drove through a big puddle of water that got sucked up the intake.
Out of curiosity I looked up my insurance. Here is a not inclusive list of exclusions for comprehensive coverage in my policy: resulting from wear and tear, freezing, mechanical or electrical breakdown or failure.
There are some other exclusions (like sound equipment etc.), but they are not relevant to the OP case. Again, this is for my insurance company, other companies may have slightly different policies.
I guess flooding could be covered if it caused by raising waters, not mechanical or electrical breakdown or failure.
Did you get car fixed and was it the drain holes under cowl?
I’m having a similar issue too call Hello. NHTSA 1 (888) 327-4236 to report a complaint and conduct an investigation. Keep any, diagnostic, receipts or pictures that you may have.
