hey I have 2013 nissan versa that has no tail lights or park lights but all other lights work have checked all bulbs and grounds ,I need to know where the tail lights are getting power ,
If you are checking fuses, I usually pull the fuse out and test it with a multi tester. They can sometimes look good to the naked eye, but may still be blown. Good luck!!
This is another webpage:
https://www.google.com/search?q=2013+nissan+versa+sedan+fuse+box+diagram&client=firefox-b-1&tbm=isch&tbo=u&source=univ&sa=X&ved=2ahUKEwit8MzGiIbeAhWrTt8KHQJKA6gQsAR6BAgEEAE&biw=1920&bih=983
This is for a nissan Note...............might be the same for the sedan:
https://www.autogenius.info/nissan-versa-note-2013-2018-fuse-box-diagram/
