Hi,
New to the forum and I hope you guys can help. The radiator fan in my versa is not working. It does not turn on when at operating temperature or when the a/c is on. The a/c is not blowing any cold air, but the freon is at proper levels. Coolant is full, and the car hasnt overheated. This all started after replacing the spark plugs. I was driving the car after replacing them and noticed the a/c wasnt working well. Brought it back to the house and tested the freon. It was a normal pressure. This was about 3 days ago. Now the fan is not coming on at all, and the a/c is blowing hot air. The a/c clutch is engaging when the a/c is on, and I can hear an audible click. I replaced the thermostat, I have checked all the fuses, and the relays appear to be fine, but electrical is not a subject im comfortable with, so Im not 100% certain that the relays are good. By visual check they show no indication of being different than a new relay. I am at a loss at this point because it seems like it could be many things, but I dont really want to just start replacing things in hopes the problem will eventually fix itself. Any help is much appreciated!
