So, I have a problem with my AC not working correctly. Details as follows:
1) AC works fine for about 1 hour.
2) Then, around the 1 hour point, the air turns lukewarm, and after another 15 minutes, the A/C is blowing hot, outside-temperature air.
3) So... after shutting off the A/C (and running with the windows down), if I wait about 45 minutes - the A/C then works fine again.
4) Then, after about another hour, the same problem occurs - Air temp goes to lukewarm, then hot.
5) I notice that the time it takes for the A/C to start putting out warm/hot air depends on how hot it is outside. For instance - in the mornings when the outside temp is ~70-75, it takes closer to 2 hours for the A/C to stop working. But, when it's 80+ outside, the A/C works as described above.
Note: The refrigerant (R134a?) in the vehicle is the original refrigerant - it has not been purged/refilled.
Does anybody have any ideas what may be causing this? Any help/advice is most appreciated!
