I recently purchased a used 2015 Versa 1.6s. I guess it's actually an "S-plus" model because it does have factory blue tooth with steering wheel audio controls and does have a power trunk release. Swimming in luxurious options I tell ya.. I actually love the simplicity, because the car is mainly for my driving age kids to use.
Anyway.. as is my custom on used purchases, I like to go through and change the fluids myself. I did some research on the ancient RE4F03B 4spd automatic this car has and according to the Nissan factory service manual, all 2014-2017 Versa S models equipped with the 4spd AT have to be both drained and filled from the transmission pan drain plug. There's supposedly a riser or pipe shoved up the drain plug that allows you to check proper warm ATF level. This is basically the same system as most Toyotas these days and a royal PITA for the DIYer.
Upon further investigation and some youtube surfing, I found that indeed it still has a dipstick tube of sorts that's buried in there out of sight. It's the same type of dummy dipstick tube with the black plastic locking cap that the CVT models use.
I managed to wrestle the cap off yesterday with some knuckle busting, sweat and swear words. I had to remove the lower half of the air cleaner housing and unclamp and move a big electrical harness to give my meat hooks better access. Man that sucker was on there. Defeating the lock/tab wasn't bad. It was the O-ring on the cap was stuck to the inside of the tube. No lube put on it from the factory apparently. I'm familiar with these caps given my 2016 Nissan Quest CVT uses the same thing and was difficult the first time around too.
My plan is to suck out as much ATF cold as I can through this tube and then refill the same amount back in. Plan to use Valvoline Maxlife which is "suitable for use" where Nissan Matic-S is called for.
Just venting and hope this helps someone. I did search for it before I posted! LOL I'll post back with my progress.
