No, I don't smoke, but I do like to have a USB plug in the cigarette lighter socket (more current and faster charging that the radio USB plug.)
But not getting any charge at the USB adapter plunged into the cigarette socket, pulled the USB adapter out of my wife's car, put it in mine and still not charging.
Any ideas on what is wrong?
Thanks!
Scott
Did you check the Fuse?
Update:
Yes I did, fortunately I bought a little package of fuses.
I had a USB charger in the lighter socket.
Pulled the changer, replaced the fuse, insert charger... popped fuse.
Remove charger, replace the fuse, grabbed USB charger from wife's car inserted into socket, worked fine.
Took my USB charger, thru it in that garbage and ordered a new one on Amazon.
My cig lighter barely works as well. What happened is I had a cheap USB charger in it for a long time and the metal rusted/corroded because of the difference in metals of the cigarette lighter and the "nipple" metal point on the usb charger itself. Ill have to get it replaced or try to clean down in the cig lighter.
3 Participants
versa122
