1 - 1 of 1 Posts
Hi I’m new to the forum and have a question about an oil leak. I have a 2015 Nissan Versa Plus with a CVT auto transmission with about 45k miles.
I am unable to get a clear answer by searching the internet and thought I would try here. I found a leak coming from a tube under the radiator. There are actually 2 similar tubes one is longer than the other. They run from the radiation to the engine. The metal tube looks rusted and needs to be replaced. I’ll replace both. After some searching, I found the parts I think I need.
Oil Cooler Tube Product ID: 21634-3HC3A
Oil Cooler Tube Product ID: 21633-3HC3A
My questions are:
  • Are these for engine oil or transmission oil?
  • If they are for the transmission how can I check to see if I need to add oil. Cannot find dipstick?
  • When I replace the tubes will I lose more fluid? Will it come spilling out.
I also cannot find a video on replacement and was wondering if when replacing the lines do need to worry about air in the lines like you would have to with break lines.
Thanks for any information you may have.
1 - 1 of 1 Posts
